New recently mounted PC problem
4 minutes ago, Princess Cadence said:So I have just finished putting together my computer however I have had issues...
My computer turns on, displays nothing through either iGPU or GPU, stays on for a little bit I think leds blink once, and then it turns off. Since by touching the power cable made it start back up again I thought it could be the issue, bought a new one but same issue apparently.
Quite frustrating, what should be the next step here? I should note I did feel there was the need of excessive pressure to make the shitty 212 mount bother me from begin to end... I have ss's and all, could it still be the power cable? it is 10A maybe I need the 15A? I'm really lost here and my brother who usually helps me better at this is in new york
Here are some screenshot's
I could really use help
Well first off
Ram should go in same colored slots (both grey ones i believe)
