G-Sync Monitor Confusion
Solved by MacAaroni,
14 minutes ago, sazrocks said:I have the 24" version of that monitor; it works great. Have you enabled G-sync? Make sure v-sync is off too. What game are you playing? Is it full screen or windowed?
Yeah i had G-Sync enabled and V-Sync off globally, but i think i just fixed my issue for good! Took a look at the Nvidia Control Panel Settings again and went under Display > Change Resolution > Refresh Rate and saw that it was at 60Hz instead of 144Hz... Wouldn't have guessed this was the issue cause I've played at higher than 60 FPS and didn't seem to have any screen tearing. I'll test this out on more games, but hopefully this was the fix i needed.
