Hey guys!
I noticed my 3930k was pretty hot in idle (44-50C) and I changed the thermal compound to MX4 from CM Essential E2. Now it's around 40-45.
During load I used to get around 80C before and now 70C (on the hottest cores).
I have two NF-P14 fans on the H110, 4 140s and one 200 in a CM Storm Stryker and no OC on the CPU. Fans run at max rpm under load and low rpm when idle. Temp in the room is around 24C.
I feel like the load temps are okayish but doesn't it idle too high ?
Corsair H110i, I7 3930K, Asus Rampage IV Extreme, Corsair Vengeance Pro 32GB, GTX780 DCu2 SLI, Intel 240gb SSD, ASUS VG247QE triple setup
https://linustechtips.com/topic/874276-h110-high-idle-temps/
19 hours ago, Radu Matei Birle said:
Hey guys!
I noticed my 3930k was pretty hot in idle (44-50C) and I changed the thermal compound to MX4 from CM Essential E2. Now it's around ()()
seems normal to me. I wouldn' worry about idle temperatures in any case, perhaps your bios is pushing more voltage than necessary during low load. but 40s is not a problem.
https://linustechtips.com/topic/874276-h110-high-idle-temps/#findComment-10834467
It's true that when idling the CPU never goes below 3GHz, but it used to be cooler and wondered if whether the H110 is dying or not.
https://linustechtips.com/topic/874276-h110-high-idle-temps/#findComment-10834600
Do you have anything like Corsair Link measuring the pump speed? Does any of the lines leading to / from the pump feel hot to the touch? Does the actual pump feel hot or warm to the touch?
"The only thing that matters right now is that you're here, and you're safe."
https://linustechtips.com/topic/874276-h110-high-idle-temps/#findComment-10834649
The pump is powered directly from the PSU. When turned on I can feel it vibrating a tiny bit, the pump is warm and the tubes are warmish.
https://linustechtips.com/topic/874276-h110-high-idle-temps/#findComment-10834666
What's your CPU voltage at? This is honestly pretty toasty for just 3.8GHz on one of these. I ran a 4930K @ 4.3GHz on an air cooler and it never went over 65C.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/874276-h110-high-idle-temps/#findComment-10834698
Full load temps seem to have gone a bit lower, but idle temps are still high. Voltages seem fine too.
https://linustechtips.com/topic/874276-h110-high-idle-temps/#findComment-10835089
