Ok, so I have an idea and I'm not sure if it is crazy or not.
I currently have a single 3TB HDD in my system, and I want to expand my storage. Lets call this original drive HDD1.
My plan is buy 2 more 3TB drive (HDD 2 and HDD3).
And here's my plan:
Use software to create a RAID 0 between HDD2 and HDD3, then create a RAID 1 between HDD1 and the RAID 0.
Hopefully this diagram makes sense. I know that RAID 10 is probably a better move, but I can't afford a 4th hard drive.
Do you guys think this would work?
DON'T FORGET TO
BEEP BEEP LIKE A SHEEP
https://linustechtips.com/topic/872786-question-re-using-raid-0-and-1-together/
And here's my plan:
I wouldnt really recommend to put a hdd in raid 0, atleast if you dont care about losing data. Raid 0 is more a thing for ssd's
Well the point of RAID 0 is for speed, so putting HDDs in RAID 0 is a common thing. The RAID 1 is meant to be redundancy for that RAID 0.
DON'T FORGET TO
yes i know but putting HDDs in raid 0 isnt a smart idea in general
This doesn't work. Combining RAID1 and 0 takes 4 drives minimum. It's called RAID1+0 or RAID10.  You can't mirror a 2TB RAID0 volume to a single 2TB drive for instance.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
You can manually mirror HDD1 to the RAID 0 using something like clonezilla, but otherwise trying what you're trying would effectively be like putting two drives in a RAID 1.  Aside from the performance issues  everyone is talking about, the 3TB drive doesn't have enough space to use all the storage from the RAID 1, so you'd be limited to 3TB of space at a single drive's speed.  In other words, you could probably program the RAID software to do this, but you'd effectively be right back where you started, but out the money for two drives.
If you really want to do RAID with 3 drives, I think that's the minimum for RAID 5.  One drive will be reserved for Parity, though, so you'll just have two drives worth of storage.
Current stuff:
Laptop:
Dell Inspiron 15 Gaming
Intel Core i5 7300HQ @ 2.50ghz
GeForce GTX 1050
32gb Crucial DDR4 2133
500gb Samsung 850 EVO
5TB Seagate Barracuda 5400RPM Laptop drive
Desktop:
Intel Core i7 6700k @ 4.20ghz
2x GeForce GTX 1080 Founders Edition
4x8gb GSkill Ripjaws V DDR4 2133
Gigabyte Z170X Gaming G1
480gb Kingston HyperX Predator
2TB Seagate Barracuda 7200RPM HDD
Corsair Strafe RGB w/MX Blue switches
Mad Catz R.A.T. 7
Lots of completely necessary "Go Faster" lights
Server:
Dell PowerEdge T30
4x Western Digital Blue 1TB 7200RPM Drives
1x4gb Hynix DDR4 2133 RAM
CoolerMaster CM Storm QuickFire Rapid w/MX Blue switches&Custom NVIDIA/QuakeCon keycaps
