Hi everyone,
I'm building my first build and I have this problem with posting. specs are
GTX 1080 TI Poseidon
ROG Crosshair VI HERO (WIFI)
Ryzen 7 1700X
Corsair RM 1000X
So when I plugged in everything, I just clicked that start button and fans turn on, everything seems nice but no post. CPU fan spins as it has to, GPU fans spin sometimes, i guess when it needs to cool down... I tried to use reset button right next to the start button. I tried one single ram too, then plugged in SSD. nothing worked... I even looked up error codes: A9 and 0d. Any ideas whats going on or how to fix?
Thanks!
https://linustechtips.com/topic/872599-no-post-first-build/
2 minutes ago, Dutuna said:
Hi everyone,
Ryzen 7 1700X
Corsair RM 1000X
Thanks!
Ryzen has notorious load time for first boot. I've heard between 10 to 30 minutes.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816239
2 minutes ago, ShadySocks said:
Try booting without the GPU
Its a Ryzen build. It needs a gpu.
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816243
You could try to go through this list. It's a good starting point.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816251
23 minutes ago, Dutuna said:
Hi everyone,
Ryzen 7 1700X
Corsair RM 1000X
Thanks!
Turn on the pc and turn off using power button and wait 5 secs Do that 6 Times.
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816302
It couldn't hurt to double check ram placement. It's a common mistake and it does seem to matter. If you're using two sticks, they should be in A2/B2 (grey slots). One stick should be in A2. Also, I think that board has a Flashback feature that allows a bios update while the system isn't powered up. Most Ryzen non-Post issues I've seen are memory related and bios updates improve memory compatibility. Perhaps that's something to look into.
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816319
Just now, Dutuna said:
it says on the board 0d. in manual D0 which is CPU initialization error
Take out the CPU. And clear CMOS then turn it on without CPU Then put CPU Back in.
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816321
Can you tell me how to clear CMOS :x
Turn off the PSU And take out the little Circle battery. Its reflective and looks like silver. Then wait 30 SEC And put it back in and turn on PSU
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816331
i did memory job well, i was following the manual a2 and b2 for both as you said and a2 for single same thing happened for both. can you help me locate that flashback button?
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816336
 It's not a button, it's a feature. Supposedly, you can put the updated bios file on a USB Flash drive and update without the system being powered on. Research it.
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816340
i think cpu is plugged in. i marked on pic with red circle the socket i used for cpu powered
Most motherboards with multiple cpu power inputs support only using one but maybe not with this motherboard so you might have to plug in the extra four pin one.
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816361
Check the connection.
https://linustechtips.com/topic/872599-no-post-first-build/#findComment-10816362
