Hey guys,
my Gigabyte G1 Gaming 970 has some issues with its display ports and gigabrick support doesn't seem to respond ... issue is that sometimes the system fully boots but the screen stays black and i tracked it back to the display ports of the gpu - hdmis, dvis work. Long story short, two options: stick with the 970 (maybe gigabytes support is kind enough to respond some day) or obviously replace it at some point. GPU prices seem to kind have normalised - what would be a worthy replacement? no intends of overclocking really, doesnt matter on pascal as much anyway cause gpu boost, but quiet operation and 4GB RAM is minimum. Low power consumptions is favored too, I'm still gaming on 1080p 60Hz and no current intends to upgrade to 1440p. I don't need a lot of power, and I'm wondering: 1050ti - would it be a downgrade? or what would you recommend? Location is germany, budget... don't want to spend too much over the sale price of the 970 which could be around 160€ probably. so stretched maximum is probably 300€ but the cheaper the better.
Thanks in advance :)
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/870000-problems-with-gtx-970-possible-replacement/
16 minutes ago, 19_blackie_73 said:
-snip-
Did you try reseating the GPU? Also it could be your displayport cable so try a new one. I say that because I have had dead cables before because I use cheap ones. I have that same GPU in my HTPC and it works fine for me.
Personal Rig:
CPU: i7-11700K  | Mobo: MSI Z490-A PRO | RAM: 2x G.SKILL Ripjaws V Series 8GB = 16 GB  | GPU: ASUS GTX 1070 Strix (I know I need to upgrade) | Storage: Samsung 970 Evo Plus 250 GB, WD Blue 1 TB, WD Red 2 TB, and WD Red 4 TB | Case: Enermax Ostrog Black and White | PSU: EVGA 750GT 80+G | Cooling: Noctua NH-U12S in Push/Pull with Black Noctua Industrial Fans, 2 120mm Noctua Chromax Fans, and Corsair AF120 on the side panel | Display: 22" Asus VE228 1920 x 1080 and a 32" Samsung (of somesorts) 1920 x 1080 on a WALI Arm (I share displays/desk with two builds) | Mouse: Logitech M705 | Keyboard: Logitech K350 | Random: 90mm of CableMod RGB Magnetic Strips | OS: Win 11 Education x64
32" Samsung CF397 1920 x 1080
Linux/test Box:
CPU: Ryzen 5 2600  | Mobo: ASRock AB350M mATX | RAM: 2x Crucial 8 GB DDR4 = 16 GB | GPU: Asus GT 1030 | Storage: Sandisk SSD Plus 120 GB, Samsung 970 Evo 256GB SSD, 2x 2TB Seagate IronWolf NAS Drives  | Case: Cooler Master N200 mATX | PSU: EVGA 400W | Cooling: Stock Cooler and 3x Cooler Master 120mm Fans | Display: 22" Asus VE228 1920 x 1080 and a 34" LG 43WL500-B 2560 x 1080 on a WALI Arm (I share displays/desk with two builds) | Keyboard: Logitech K270 | Mouse: Logitech M185  | OS: Ubuntu 22.04 LTS and Windows 10 Pro x64
13" Macbook Air M1:
CPU: Apple M1 8-Core and 7-Core "GPU"  | RAM: 8 GB DDR4  | Storage: 256 GB | Display: 2560 x1600 Retina Display | Mouse: Built-in trackpad and Logitech M557 | Keyboard: built-in keyboard and Logitech K480 | OS: MacOS Monterey
Laptop (Acer Pedator Helios 300 2017 edition) (Don't use as much anymore since graduating college and mostly using my Macbook and HP Elitebook for Work):
CPU: i7-7700HQ  | RAM: 16 GB DDR4  | GPU: GTX 1060 6 GB | Storage: Samsung 980 500 GB SSD and Seagate 1 TB Firecuda | Display: Acer IPS 15.6" 1920 x 1080 Display | Mouse: Logitech M557 and built-in trackpad (never use lol) | Keyboard: built-in keyboard and Logitech K480 | OS: Windows 11 Pro x64
Home Theater Setup
Computer: M1 Mac Mini w/8GB RAM and 256 of Storage (plus a external 500GB Samsung T7 for Plex) | TV:LG 4K - 55" UQ9000 LED | Speakers: Sonos Ray and 2 Sonos One SLs for Rear Surround | Media Box: Apple TV 4K | Consoles: Xbox Series S and Nintendo Switch | Mouse/Keyboard: Logitech K400 | HDHomerun Flex 4K and HDHomerun Flex Duo
Other Devices I use:
Phone: iPhone 13 Mini 128GB  | Tablet: iPad Mini 5 64GB LTE | Earbuds: Airpods 3 | Watch: Apple Watch SE 44mm
2 minutes ago, warlinty said:
it'd be a downgrade
@19_blackie_73 You would have to get at least a 1060 3gb to have the same preformance. I have a 1070 in my rig and it is comparable to a 980.
Here is the link to 3dmark results and set it to advanced search and just use a 7700k for the CPU since its a widely available CPU and it is one of the best ones for gaming right now (yes I know there is a 8700k out, but not many people have them yet) and then change the GPUs around and add it to compare. These are real results by people so you can get a general idea. https://www.3dmark.com/search?_ga=2.220365528.1187412964.1512584670-180670829.1512584670
Personal Rig:
Linux/test Box:
13" Macbook Air M1:
Home Theater Setup
yeah, already did that
driver many times new installed, updated and even windows fresh install
hooking up other devices via displayport on the monitor
new cable
and what not... with hdmi it works, vga with dvi to vga is kinda blurry has vertical lines running down the screen, gives me headaches will typing this...
hoping that gigabyte manages to answer in a shorter period than 1 year...
1060 3GB is no contender for me as I sometimes manage to max out the 3,5 GB on the 970 with computing stuff, so at least 4GB is my minimum... so 1050ti or 1060 6GB basically. Dunno what I should think of the RX570 becauese kinda as expensive as the 1060 6GB and less performance, 580 is >300€
- Ryzen Build -
2x Dell UP2516D
1050ti would be a downgrade, 1060 3gb would be 10% faster for 200dollars, just stick with the 970 imo
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
