More fans necessary?
Go to solution Solved by Hiya!,
1 minute ago, nottherealzeesh said:
Ok... so if I buy one fan for the top mount, and then have the one for exhaust and the rad, will that be enough to keep the system cool? It'll be an i5-7600k and an RX580
As i said the case has poor airflow.
But i think it will be fine although i prefer to use air cooler than AIO for that type of case.
Becase u can install 2x fan at the front as an intake and 1 as an exhaust and it will be enough.
But its up to you.
If your budget its not limited look for FD Meshify C it has open front panel for more airflow support up to 360 rad at the front if u remove the hdd cartridge, 2x 12/14cm fan for the top, and 1x 12/14cm fan at the rear.
And it looks more premium
Hi,
I'm building a PC, and for a case I was planning on using the Phanteks Eclipse P300. The case only comes with a single rear exhaust fan, but I'm planning on installing a 240mm AIO water cooler. I've made plenty of PC's with air cooled CPU's but this will be my first build with water cooling. If I install the radiator, will that and the one fan that comes with the case be enough for airflow? Thanks.
https://linustechtips.com/topic/869715-more-fans-necessary/
The case itself has a really poor aiflow not to mention the front panel design.
U might need to add a fans at the top of the case as an intake because your AIO will be blowing hot air.
Gaming Mouse Buying Guide (Technical Terms,Optical vs Laser,Mice Recommendation,Popular Mouse Sensor,Etc)
[LOGITECH G402 REVIEW]
I love Dark Souls lore, Mice and Milk tea  ^_^ Praise The Sun! \[T]/
I can conquer the world with one hand,As long as you hold the other -Unknown
Its better to enjoy your own company than expecting someone to make you happy -Mr Bean
No one is going to be with you forever,One day u'll have to walk alone -Hiromi aoki (avery)
BUT the one who love us never really leave us,You can always find them here -Sirius Black
Don't pity the dead,Pity the living and above all those who live without love -Albus Dumbledore
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789346
I have a case similar to yours and run a radiator up front as intake with three on top and one rear as exhaust. For me that's fine
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789371
P300 only support 1 120/140mm fan at the top.
Even p400 only support 2 fans at the top.
So what is your case exatcly?
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789389
Phanteks enthoo pro ?
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789395
Duh :P  its not similar
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789414
Really, my bad xD I just searched up his case and to me they kinda look the same, my bad though
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789467
5 minutes ago, nottherealzeesh said:
And just making sure... the 240mm rad will fit fine in this case?
It will at the front.
No worries it happen xD
Just Fyi P300 is the cheaper version of P400 TG.
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789481
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789489
But its up to you.
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789508
But its up to you.
Unfortunately I'm limited to about $50-60 for the case. Do you know of any other cases that might be better for this? I'm building this computer for a friend, and he specifically requested water cooling.
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789514
Fractal design focus G maybe.
But its an old case it doesnt have psu cover,no tempered glass,and no Fancy RGB.
Just an acrylic panel on the side.
But it has open front panel design and support up to 280mm radiator at the front.
Support 2x fan at the top and 1 for the rear as usual
asus-rog-fractal-design-focus-g-amd-ryze
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789546
Yes I was looking at that as well. I'll ask my friend if he'd rather switch to air cooling, if not, I'll just build in this case and buy an extra fan or two. Thank you for your help
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789596
Dont praise me
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10789616
omg nobody ever told OP not to buy the i5 7600k nowadays
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10792452
It's not really a shock to me to be honest, I didn't see much talk of hardware specs here...
https://linustechtips.com/topic/869715-more-fans-necessary/#findComment-10792493
