Hey,
as Christmas is nearing I wanted to make myself a small gift of a new gaming PC.
As the title says I wanted it to put it in a small-ish case, I have chosen some of the things that I want to be in but they all can be subjected to change. I live in Poland but I might be able to get a hold of some parts from the US. My budget is around $1200 or ~4000 pln but if needs be can go a bit higher. I want the PC to be able to play new games at 60FPS on preferably high or higher settings.
The parts I have initially chosen:
Case- Phanteks Enthoo Evolv ITX
GPU- some kind of GTX 1070 (depends on availability)
CPU- i5-8400
Motherboard- ASUS ROG Strix H270I Gaming
I know I need a cooler, memory, storage, a power supply and if you can recommend any either wide 1080p or a 1440p monitor.
https://linustechtips.com/topic/869615-small-case-rig/
If you can, swap the Evolv ITX for the Fractal Design Nano S. It has way better airflow and looks as good IMO
https://linustechtips.com/topic/869615-small-case-rig/#findComment-10788203
