So I have an Alienware 13 (specs at bottom of my signature) and it is great but the battery life is way lower than it should be and it is bulky and I have seen similar laptops which weigh less and are less bulky. I am probably not going to change it for something else but if I was, what are some good 13/14 inch laptops with a GTX 1060 minimum and a decent CPU (i5 or i7) with at least 2 m.2 slots so I could move my 1tb m.2 drive from the alienware. Preferably with a back lit keyboard too. Also it needs to be relatively light weight as the Alienware was a pain to carry on long journeys as it is so heavy.
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/869418-replacement-for-alienware-13-r3/
Do you have a maximum budget?
Because there are plenty of options like Razer Blade with 1060, lightweight, great battery but expensive.
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
I got my Alienware almost new for around £1000 so it would need to be around that. I don't mind going for second hand.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
The 1060 Alienware 13" are almost double what you payed so I don't think that there are that many option for 13" laptops with a 1060.
I don't know what used razer blades go for.
I think an other option is a massive power bank which gives your laptop extra juice to draw from.
Somebody else might be able to help you better :/
Desktop
Laptops
Dell 7577
Macbook pro 2018
I mean unless I win the lottery, I won't be changing it any time soon as I just spent so much upgrading my PC. What I will probably do is send the laptop in to dell to get the battery replaced as I am sure that is the issue as on eco-mode (where it uses integrated graphics instead of the DGPU) it should last at least 4 hours but it barely lasts one hour.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
hey there m8 i think i found the perfect fit for u https://www.amazon.co.uk/MSI-i7-7700HQ-Graphics-Windows-Leopard/dp/B074LMNWZB/ref=sr_1_5?ie=UTF8&qid=1512468262&sr=8-5&keywords=gaming+laptops You can just replace the nvme ssd and sell it on ebay or something
edit:just realized i was looking at it with usd and plugged the wron numbers but with that performance and just 200 quid over budget i think you should just get it
Edited by truecrafting
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
PNY XLR-8 EPIC-X DDR4-3200 CL16 32GB
GPU
ASUS ROG RTX 2070
STORAGE
SAMSUNG 850 EVO, 2xSEAGATE BARRACUDA PRO 1TB,A2000 1TB
Case
NZXT H500
PSU
Enermax Revolution DF 650W
MONITOR
MSI MAG272,LG 22MP68BQ,DELL D2015H
PERIPHIRALS
Ducky One 2 (HORIZON) || Glorious Model O- Pink || G305 || Razer Nari Essential || HyperX Cloud II
Gigabyte Aero 14? Though it's pretty steep in price, but has a whopping 94Wh battery that can last you about 7hrs of normal usage. There are not many variants of 13"/14" laptops with a GTX 1060 and they're not cheap mostly to get when bought new. You're pretty lucky getting your Alienware 13 at around £1000 with GTX 1060.
Daily drivers:
- HP Elite x2 1012 G2: Intel Core i7-7600U, Intel HD Graphics 620 + Aorus Gaming Box GTX 1080 eGPU, 16GB LPDDR3-1867, 256GB Toshiba NVMe PCIe 3.0 x4 SSD + 128GB Toshiba Exceria UHS-1 U3 MicroSD, 12.3" 2736x1824 + HP Pavilion 22cwa Monitor 21.5" 1080p IPS, Windows 10 Pro 64-bit
- LG V20 (H990DS): Qualcomm Snapdragon 820 (ARM-based), Adreno 530, 4GB LPDDR4, 64GB eMMC UFS 2.0 + 64GB SanDisk Extreme UHS-1 U3 V30 MicroSD, 5.7" IPS LCD 1440p + 2.1" 160x1040, Android 7.0 (LG UX 5.0)
Other devices:
- Lenovo IdeaPad Y400: Intel Core i7-3630QM, NVIDIA GeForce GT 750M SLI, 16GB DDR3-1600, 120GB Kingston mS200 mSATA SSD + 1TB HGST Travelstar 7K1000 7200rpm 2.5" HDD, 14" 768p, Windows 10 Pro 64-bit + Ubuntu 16.04 LTS 64-bit [retired]
- Dell Venue 11 Pro (7139): Intel Core i5-4300Y, Intel HD Graphics 4200, 8GB LPDDR3-1600, 256GB SanDisk X110 M.2 2260 SATA3 SSD, 10.8" 1080p IPS, Windows 10 Pro 64-bit + Ubuntu 16.04 LTS 64-bit [retired]
- Acer Iconia W4: Intel Atom Z3740, Intel HD Graphics, 2GB DDR3L-1033, 64GB Samsung MCG8GC eMMC, 8" IPS WXGA (1280x800), Windows 10 Home 32-bit
- Asus ZenFone 2 ZE551ML: Intel Atom Z3580 (x86-based), PowerVR G6430, 4GB LPDDR3, 64GB eMMC, 5.5" IPS LCD 1080p, Android 6.0.1 (Asus ZenUI)
- New Nintendo 2DS XL
I know you can grab the new Inspiron 7577 for $950 with a 1060. Only has the i5-7300HQ, and it's a 15" machine... but it's under a grand! :D
S.K.Y.N.E.T. v4.3
AMD Ryzen 7 5800X3D | 64GB DDR4 3200 | 12GB RX 6700XT |   Twin 24" Pixio PX248 Prime 1080p 144Hz Displays | 256GB Sabrent NVMe (OS) | 500GB Samsung 840 Pro #1 | 500GB Samsung 840 Pro #2 | 2TB Samsung 860 Evo1TB Western Digital NVMe | 2TB Sabrent NVMe | Intel Wireless-AC 9260
On 12/5/2017 at 5:38 PM, EG! said:
Razer Blade
On 12/5/2017 at 6:06 PM, truecrafting said:
Avoid these, Razer laptops have poor internal quality, poor QC and poor support. MSI GP laptops have mediocre build quality and overpriced
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
that's the thing with laptops there har d to choose that fine line between Quality and Performance i personaly think if Silver carea about build quality he's gonna have a hard time finding that perfect laptop.
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
GPU
ASUS ROG RTX 2070
STORAGE
Case
NZXT H500
PSU
MONITOR
PERIPHIRALS
