i just bought a new psu the SEASONIC FOCUS PLUS GOLD 750
it came with 2cpu cabels
https://gyazo.com/7bd2c9d48660bb1a40a14aafbb6e45d4
the pin shapes are like this from the psu
https://gyazo.com/b437c1bc9beba7dfa14c36c20c1105e6
the motherboard connector is like this
https://gyazo.com/f2eabe5dff4eb9d09cf8f08a78ce9bd6
so according the the configuration  on the motherboard it should be with lip on top  top:round square square round
        bottom:square round round square
now to 8/4pin connectors that came with the psu are
        top:round square round round
        bottom:square round round round
this is the motherboard
https://www.gigabyte.com/Motherboard/GA-Z270-HD3P-rev-10#kf
Pleas help fast
https://linustechtips.com/topic/868161-cpu-p4-p4-help/
CPU cables 2x4
sticking out thing goes in top
plug them both in at the cpu connector port
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/868161-cpu-p4-p4-help/#findComment-10774641
The connectors are keyed that way  (with mix of rounded and square holes) so that you won't accidentally plug pci-e 8 pin connectors in the cpu power connector. The pci-e power cables have the polarity reversed so plugging them in the cpu header would be bad.
The "round" pins can go into square holes in the headers. You just can't plug square pins into rounded holes in connectors on motherboard.
The two cpu power connectors are these :
So normally you can split the 8pin connector from the power supply and only one half of the connector can be inserted in the 4pin connector on the motherboard.
The way the connector is shaped on your power supply allows for either of the two 4pin parts to be plugged in that small 4 pin connector (if your motherboard had one).
So you have the part with  square, round, round, square that fits perfectly into that cpu 4 pin header, but you also have the part with four round pins which will also fit into the cpu 4 pin connector.
If the 8 pin connector can't be split in two, then it's extra useful because it allows to plug the 8pin connector onto the motheboard with either the left or right part of the connector hanging outside the header (depending on how much space there is around the header)
https://linustechtips.com/topic/868161-cpu-p4-p4-help/#findComment-10774765
