Suggested camera body for £500-700
1 minute ago, pbx2 said:Another two things then, Is the top LCD like the 80D has actually worth it? And what lenses should I get over time, I'll most likely need a stabilized telephoto (Maybe one of the canon 75-300s) and maybe one of the stubby little 50mm lenses, Since my main focus is Day & Night transportation related photos and 3D Natural forms, What should I be adding to my list of things to get over time, Along with another battery or two and more than one SD Card.
The top lcd is sort of redundant now days, because all the relevant information is displayed in the viewfinder anyway. I myself have gotten used to using it since the days of film, so now I can't live without one, but I suspect its something like being used to wear a watch, if you leave home without it you feel naked, even if your phone is glued to your hand all day.
Well that depends on how far you want to take it. The 50mm 1.8 STM is an amazing lens, and given its very low price and size, I see virtually no reason not to get one. For a telephoto, it really depends on how far you want to take it.
Here are some options (I'll rank them from most serious/best to worst for you):
Sigma 50-100mm f/1.8, great lens, super sharp and a 1.8 aperture in that range zoom is unheard of. (but its at £999)
or, if that is too wide, maybe a tamron 70-200 f/2.8 VC G1, I just picked one up myself for just under £600 used.
If those seem too expensive (even though as far as lenses go they aren't), a 70-300 will get the job done, but it won't be the fastest, sharpest etc. At least its small enough not to be a nuisance to carry around.
I would also look at a wide angle, like the Canon EF-S 10-22mm, which goes for about £250 used and gives great IQ given the price, even though it costs considerably more new.
But, I do believe you are getting too far ahead of yourself. The 17-50mm is a great multipurpose focal range and will cover a lot of your needs. Get that and use it as a benchmark for how much longer or shorter a focal length you'd need. If you need more recommendations for lenses in the future, then just ask again. But be aware, camera gear is expensive, if you think a £500 lens is expensive, it really isn't.
If you are going to be doing night shots, especially long exposures, a tripod will certainly come in handy. In that case I recommend 3 legged thing myself. Manfrotto, Benro and Mefoto also do some pretty cool stuff, but if you do buy one, get a good one rather than a cheap one, trust me. You'd normally need a remote trigger(pretty cheap in the first place), but the 800d has a wifi connection and the Canon app is pretty neat, so it isn't really necessary.
