I have been thinking about this for a long time and i really want to know how a case with a solid plastic or metal front panel case work. Like wouldn’t the temperature in the case go up since there is no intake from the front and wouldn’t big aio have the same problem, unless there i’m just overthinking this and the solid front panel does’t affect the temps that much
https://linustechtips.com/topic/866009-solid-front-panel-case-how-do-they-work/
Watch GamersNexus review of the Bitfenix Enso or any review of the Enthoo Evolv. Yes, hotboxing your PC is a bad thing.
Most solid front panel cases do have ventilation holes, usually on the top and bottom, or the sides. But most of the time, these aren't adequate enough. They tend to be too small, poorly placed, or both.
solid front pannels will increase temperatures in the case seeing as they dont take in as much air generally, but most of it can be mitigated with about 3-4 cm of vents all around the frontpanel
Builds:
