Projector for dish network
Arkianine
Anyone recommend a good projector under $1,000 for dish network , was thinking  of a 90 inch screen. I have heard so many different stories for and against.
I have the iRULU projector and I really like it, it produces a 120 screen quite well, pretty sharp, quite bright for the price point however you can definitely tell it would be better if it had a higher native resolution. If you want a budget projector then go with the iRULU but because you have quite a bit more to spend I would recommend going with one of the 1080p native resolution LG projectors.
