Building a Emulator Pc
Go to solution Solved by LHJKO,
wanted something newer you get this and an old gpu
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($99.99 @ Amazon)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($54.99 @ Newegg)
Memory: Crucial - Ballistix Tactical 4GB (1 x 4GB) DDR4-2666 Memory  ($48.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($41.77 @ OutletPC)
Case: Raidmax - Vortex ATX Mid Tower Case  ($15.98 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Total: $291.71
Generated by PCPartPicker 2017-11-23 11:33 EST-0500
or something like https://www.ebay.com/itm/Dell-Optiplex-390-Desktop-Computer-i5-3-10GHz-8GB-Windows-10-HDMI-PC/172932355372?hash=item284392552c:g:ercAAOSwJQdXBGLf and toss a 750ti in or something
Hey guys I need some help! I have no experience in building a budget cheap pc but I wanted to build one for emulating Wii and playstation 1 games. I would hook this up in my livingroom it does not have to be a powerfull system just something to play mario cart..  crash... ext. if any of you have suggestions I would like to stay under 300 if at all possible I have a wireless keyboard and mouse as well as hdmi cables to hook it to my tv. for dolfin which is the emulator I use it requires
  • 64-bit CPUs and Operating Systems are required.
  • Windows XP is no longer supported. Windows Vista is no longer officially supported.
  • Direct3D10/OpenGL3 Required. This means AMD Radeon 4xxx, NVIDIA GeForce 8xxx, or Intel HD 2xxx minimum! Anything older than that will most likely not work or will have significant glitches.
https://linustechtips.com/topic/863885-building-a-emulator-pc/
Just now, Kimmaz said:
for $300 you could buy a used ps1 with 10+ games and a wii with a few games depending on how many games you get with the system and how many you have to buy seperatly.
I understand that but I would like to browse the web sometimes as well as have one system for all those games and maybe games like castle crashers.
https://linustechtips.com/topic/863885-building-a-emulator-pc/#findComment-10736647
Total: $291.71
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/863885-building-a-emulator-pc/#findComment-10736722
Total: $291.71
While the Ryzen would be more versatile, I would recommend a cpu with a higher clock speed. Single thread performance is very important to emulation, so something in the range of 4 GHz or faster would be suitable.
My eyes see the past…
My camera lens sees the present…
https://linustechtips.com/topic/863885-building-a-emulator-pc/#findComment-10737646
