Heating issue
Greenski
So I bought a new computer on sale this is it https://www.bestbuy.com/site/ibuypower-desktop-intel-core-i7-7700k-16gb-memory-nvidia-geforce-gtx-1080-240gb-solid-state-drive-1tb-hard-drive-black-gray/6030300.p?skuId=6030300
It works really great and runs games really well. However the GPU gets pretty hot when I play pubg and the tempered glass gets hot where the GPU is mounted.
So I installed 2 exhaust fans at the top and 2 intake fans in the front, but as you can see by the front panel there is little to no air flow getting in besides a small cut out at the bottom and the sides have small holes.
When I take the front panel off and remove the dust covers it runs very cool.
So basically is there a way to get better intake airflow with out having to remove the front panel? or maybe modify the panel so air can get in there or should I just leave it off when I play certain games.
Also the magnetic mesh dust cover things seem to really drag down the air flow as well, is there an alternative to this?
And yes I don't know diddly shit about computers.
Thanks.
7 minutes ago, Preston builds said:
liquid cooling?
also its good to have more output than intake fans
Noooo. More exhaust than intake will just lead to crazy dust build up. More intake will have the same effect (more airflow) but with much less dust
That's an F in the profile pic
22 minutes ago, Preston builds said:
liquid cooling?
you must enjoy dust
1 minute ago, ImNotThere said:
you must enjoy dust
if you can be bothered to clean out your dust filters once a week you should be good lol
and the rest of tgmhe system? lul
negative air pressure=bad pressure imo
positive air pressure and change dust filter mesh size or remove filter
What are your temps?
temps are,
CPU- 60-80C
GPU-80-90C
MOB- 50-60C
and the ssd will get up to 50c since it's right below the gpu
1 hour ago, Greenski said:
temps are,
CPU- 60-80C
GPU-80-90C
MOB- 50-60C
Is the i7 overclocked ? What cooler do you have on it? As for the GPU, that's a little warmer than I'd like. Generally aim for under 84 (as 84 is throttling temperature). Make sure you have enough fans on it and make sure the cooler is decent. Upload a picture of the inside!
