how many watts can a 1080 ti output and utilize?
echy
how many watts can a 1080 ti (gpu) utilize?
for example lets say i have a 1080 ti in a computer rig with a 1600w psu.
will the 1080 ti be able to get around 1200 watts of the psu? or will the 1080 ti max out (have a limit) on how much watts it is able to utilize?
There is a finite amount of power it can use -- around 300w~ under reasonable overclocks (e.g. no LN2). To get it to use more power you have to overclock it further and push more power to it (which requires better cooling or leads to a dead GPU).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
it only draws around 350W of power. if you want it to consume more, overclock it.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
It will only use what it needs (~300W), regardless of how powerful your PSU is.
Unless your PSU is not powerful enough, in which case it will either catch fire or shut off.
how do you know that the 1080 ti is able to reach around 300w?
