I am looking for a new gaming mother as
i am currently in the middle of upgrading my computer. The cpu i have is a cpu i5-4460 with a lga socket of 1150.  I currently cant find many gaming
mother boards for my cpu (round £100)  Does anyone know a gaming motherboard that you would recommend to me?
Thank you
https://linustechtips.com/topic/860359-i-need-some-help/
gaming mother o.O
Motherboards cannot affect the gaming performance of your CPU btw. No need to upgrade that unless you look for better aesthetics.
Desktop benching:
https://linustechtips.com/topic/860359-i-need-some-help/#findComment-10704548
What is the reason you would want to upgrade your motherboard to the same processor? Performance gains, although existing, are marginally slim to not noticable between 100's of dollars price range.
Connectivity and features are things that can be concidered a reason to swap boards, but if you are looking for a performance boost you will have much better results sourcing a better LGA1150 CPU. I can find 4770K's for about 150EUR around here (Belgium), with the 4770 going under 100EUR if you don't want to overclock.
Keep in mind, 'gaming' is a term that is used by manufacturers, not an indication of performance.
What GPU are you running? First place to look for upgrades ;)
https://linustechtips.com/topic/860359-i-need-some-help/#findComment-10704574
OK well that CPU is not going to be bottlenecked in the slightest by your current CPU so I don't see the need to upgrade the CPU now unless you are going to run an even better graphics card than a 1050.
It'd probably be helpful to everybody helping you for you to list your full spec.
Probably gaming or helping technophobes with tech...
https://linustechtips.com/topic/860359-i-need-some-help/#findComment-10704649
Your motherboard and CPU are enough for your GPU as is, getting a different motherboard will do zero difference and you should only buy a new motherboard if you'll also upgrade your processor to something newer.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/860359-i-need-some-help/#findComment-10704658
43 minutes ago, userzero said:
Why are you upgrading the MB? Get a new gen CPU and MB for a start and go from there
No. There is barely a gain, especially not one that's worth the money. He should definitely stick to 4th gen.
32 minutes ago, Isellping said:
Ok. So to upgrade my computer for better performance i should upgrade both my cpu and motherboard? At the moment i am wanting to upgrade part by part but i wont be able to do that when upgrading my cpu. I am very confused and what i should do.
Drop in a new CPU, an I7 4770K or I7 4790K
29 minutes ago, Isellping said:
I have recently upgraded my gpu its a rog strix gaming geforce gtx 1050
Or not. Don't upgrade anything. Get a better gpu first.
Builds:
https://linustechtips.com/topic/860359-i-need-some-help/#findComment-10704680
I am very thankful for your guys help. I have actually been doing some research my self and have found this cpu : Intel BX80677G3930 CPU G3930 2.90 GHz 2/2 Kaby 1151 Socket Desktop CPU Processor - Black https://www.amazon.co.uk/dp/B01MYTY55V/ref=cm_sw_r_cp_api_M.ydAb0Y1Q0XY that is a 1151 lga. Is this any good? If it js good i might buy this and a motherboard. Thank you
https://linustechtips.com/topic/860359-i-need-some-help/#findComment-10704940
