PSU Recommendation (Fully modular replacement)
Solved by PrinzyXX,
59 minutes ago, CromaT said:There main reason i was to replace it is because i want a fully modular replacement and my current PSU is getting pretty old now, Had it since 2011, I am just looking for a fully modular replacement which will provide the required wattage I need with some additional headroom. So far I am leaning towards a 750-850watt.
A PSU in that wattage range should sit well in its efficiency peak under load. A top rated fully modular 750W PSU would be https://www.wootware.co.za/evga-220-g2-0750-xr-supernova-750-g2-750w-80-plus-gold-certified-fully-modular-desktop-power-supply.html as recommended by the Jonny Guru website. It scores a 9.8 out of 10, and should have all the cables you will need for GPU and CPU
