It depends what you want to do. Windows will work fine with just SSDs, but if you want to store a lot of videos, I'd recommend a hard drive.
My main computer:
i7 6700k || GTX 1070 || Asus Z170 RGB || C.M. Hyper 212 EVO || 16GB RAM || 256GB NVMe SSD || 500GB SATA SSD || 12TB total HDD || Define R5 Blackout || 850W PSU
More Details Below :)
CPU: Intel Core i7 6700k                             GPU:  EVGA GTX 1070 FTW                                  |  Motherboard: Asus Z170 Pro Gaming Aura
CPU Cooler: C.M. Hyper 212 EVO             RAM: 16GB Kingston Fury 4x4 DDR4 2400MHz         SSD:  Intel 256GB NVMe SSD & Plextor 500GB SATA SSD
Hard Drive:  WD 2TB Black, 2TB WD Blue, 8TB WD Red     Case:  Fractal Design Define R5 Blackout Edition   PSU:  Be Quiet! Dark Power Pro 11 850W
Additional Computer Parts: NZXT Hue for LEDs
Peripherals: Dell U2414H (x2) || Corsair Sabre RGB || Corsair K95 Platinum || Sennheiser 558's || Modmic
Pictures of setup:
https://linustechtips.com/topic/858438-do-i-need-a-hard-drive/#findComment-10684190
Theoretically, you could store everything in the RAM(probably not doable) or on a flash drive without ever needing internal storage...
https://linustechtips.com/topic/858438-do-i-need-a-hard-drive/#findComment-10684195
Well yes but that's not the point. SSD only is fine and the biggest advantage is the silence you get from using only solid state. I would recommend using a mass storage HDD and a smaller SSD just because it's so much cheaper. Your choice though, just remember that games don't really get any advantage from being on an SSD except slightly faster load times
That's an F in the profile pic
https://linustechtips.com/topic/858438-do-i-need-a-hard-drive/#findComment-10684220
Usually it goes like 1 SDD for boot and 1 HDD for storage, if your windows and main programs are installed on the SSD every thing will be snappy and fast, you can leave stuff like files, sound, videos, games and whatever else that won't benefit from the fast load times (at least after the game is already load), while small files like a movie opens at the same speed regardless the storage.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/858438-do-i-need-a-hard-drive/#findComment-10684264
