Antec p8 case
DDr4 2400 ram
ryzen 5 1600 CPU
msi x370 gaming pro carbon
gtx 1070 ti AMP edition
2x128 SSD
1x1tb HDD
PSU-600to650W (I NEED A BUDGET PSU, NO MONEY PLZ HELP) under 75usd
Any suggestions for a cooler, a cheap one... and do I need one? I heard the stock cooler for ryzen 5 1600 was pretty good even for highish OC
https://linustechtips.com/topic/855615-psu-for-my-build/
1 minute ago, myselfolli said:
The wraith cooler is quite okay, yes.
But don't (ever) cheap out on your PSU. In the event of its death, it may take some parts down with it
Then any suggestions, i have a bit of money left but not much more...
https://linustechtips.com/topic/855615-psu-for-my-build/#findComment-10655165
A location would be nice. For now I will assume you’re in the USA. This is the best deal on PCPP for a PSU right now.
https://pcpartpicker.com/product/WrNypg/seasonic-focus-plus-gold-650w-80-gold-certified-fully-modular-atx-power-supply-ssr-650fx
https://linustechtips.com/topic/855615-psu-for-my-build/#findComment-10655177
I live in Hong Kong, I tried searching that model and cannot find in the website I use.
https://linustechtips.com/topic/855615-psu-for-my-build/#findComment-10655219
600-650W is just bullshit, you don't need that.
450-550W is fine.
As for 'highish OC', don't bother and invest in memory, that might give you more performance than the 200MHz you can squeeze out of the chip.
If nothing changed, Ryzen is a bad overclock chip.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/855615-psu-for-my-build/#findComment-10655261
7 minutes ago, focus2003 said:
A seasonic would have been very good, but in that case you can go for a Corsair CX550M, but it must be a gray unit.
No, Seasonic has some not that great units.
And you must never ever ever go and buy things by Manufacturers ever.
You always have to take a look at what you want to buy and get that.
https://linustechtips.com/topic/855615-psu-for-my-build/#findComment-10655264
I meant the one he offered, I just didn't think of writing the whole name. Although anything past the S12II of Seasonic's PSUs are pretty decent overall.
https://linustechtips.com/topic/855615-psu-for-my-build/#findComment-10655337
Meh, S12II/M12II/M12II EVO are kinda terrible
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/855615-psu-for-my-build/#findComment-10655343
No, not really...
With what I've been hearing behind the scenes and seeing in Forums, Seasonic isn't that great. Some Seasonic made units seem to have a reliability Issue and die prematurely with failure modes that sounds like capacitors are dead/dying...
The G-Series might have been OK electrically but in terms of noise they aren't good units - there are just way better options on the market...
And there is the S12II/M12II variants (620W and below) wich are loud, badly protected, group regulated...
The 750W and above variants are OKish. A bit on the loud side but otherwise they are OKish...
So, no, you must never ever ever just take the manufacturer of the PSU. And just because someone makes the units themselves doesn't mean they are any better than outsourced ones...
https://linustechtips.com/topic/855615-psu-for-my-build/#findComment-10655399
