G-Sync monitor 2560x1440
Slayerofhope
one is TN panel the other is IPS. The best way to choose is to learn what each has to offer and what their respective drawback are as well. Roughly, TN has better response times which can be prefered by some, where IPS has better color/contrast and viewing angles as well as usually a higher price tag compared to TN. Both work just fine.
If you want a more in depth explanation between the two types to see which one you might like better, Gamers Nexus has a great guide and description breaking down the different types of panels with PRO's/CON's.
20 minutes ago, Slayerofhope said:
What to get Asus PG278QR
or Asus PG279Q
What refresh rate are you hoping for?
They both 144
I have the TN version of the ROG swift, it's a GOOD tn panel, so don't let that bother you too much. The panel itself runs a bit cool though, even after calibration. My only main gripe. Starting next week though, it will be my secondary monitor as I have the new alienware 34" on its way :-)
SLI 1070 Setup for sale!!!
