Hello everyone, seeking for some help and asking the same questions you probably see on these forums ( disclaimer: i have read about power supplies, watts etc but i wanna make sure)
My planned build:
Motherboard: Motherboard Gigabyte Ga-ab350-gaming Am4 Ddr4
CPU: Ryzen 5 1600
Cooler: Coolermaster evo 212
GPU: either  ASUS GTX 1060 6GB OC DDR5 DUAL or Gigabyte GTX 1060 6GB DDR5 Windforce OC (still not sure which one is better for my goals)
RAM: 1 x Corsair DDR4 8GB 3200Mhz Vengeance LPX Black
PSU: Not sure which one, i've read the tier list but still unsure as for my goals
Case: Gamer Thermaltake Versa C21 Rgb Mid Tower
HDD: 1TB
Goals:
 - Play dota2 smoothly, high fps, no freezing
- Stream Dota2, not expecting the greatest quality but some quality it can be enjoyable and not affect gameplay.
Thanks in advance!
https://linustechtips.com/topic/855003-building-this-pc-come-help/
My planned build:
CPU: Ryzen 5 1600
HDD: 1TB
Goals:
Thanks in advance!
Looks good. Pick the cheaper GPU if there are no known problems or significant OC differences.
ORANGE SCREEN WINDOWS 10 VALUE OVER TIME - PC VS MAC
i5 7600k @ 5.0 GHz xD
Corsair H60 with Noctua NF-F12 iPPC-3000 PWM
MSI Z270-A Pro Motherboard
EVGA 1050 Ti SC
16 GB Corsair DDR4 @ 2400 MHz
500 GB Sandisk 950 PRO - Windows 10, Elementary OS, Zorin OS
500 GB Sandisk 850 PRO
1 TB WD Blue
Corsair CX750
1 x Corsair AF120 Quiet Red Led
Rosewell Tyrfing Case
EliteBook 8570w
i7 3720QM @ 2.6 GHz
Quadro K1000M
24 GB DDR3 @ 1600 MHz
250 GB SanDisk 850 EVO - Elementary OS, Windows 10, Debian
i5 3470 @ 3.2 GHz
EVGA 750 Ti SC
8 GB DDR3 @ 1333 MHz
240 GB SanDisk - Windows 10, Linux Mint
1. Get a different motherboard
2. Use the stock cooler
3. CX450M or Pure Power 10 400/500
4. SSD?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
would you recommend any of these? http://compragamer.com/index.php?seccion=3&cate=34&nro_max=10 (Website is in spanish, not sure if you'll be able to understand)
Thanks for you fast reply though
Looks great! I'd personally go for the Gigabyte 1060 for aesthetic reasons, the Windforce heatsink looks better than the Asus Dual heatsink IMO.
The EVGA one looks like it should work for you, despite being 600W...
I wouldn't recommend any, except for this expensive unit:
http://compragamer.com/index.php?seccion=3&id=6276&nro_max=10
any other stores?
Full Specs
Helios EVO (Main):
Delta - Laptop
The case and the motherboard are the parts that i already bought, damn :P
I would highly suggest getting another unit if that option is available.
Full Specs
Helios EVO (Main):
Delta - Laptop
Thanks for your fast response, i read that the evga 600w is tier 6, so i wasnt really sure
*Tier 4
I still wouldn't buy it though. For a gaming PC I would at least get a Tier 3 unit.
Full Specs
Helios EVO (Main):
Delta - Laptop
2 minutes ago, merlain10 said:
Yeah i can go after any unit you suggest !
Try to find the Corsair CX450M, and if you are outside the US/Canada, try finding the Be Quiet Pure Power 10. Generally any unit Tier 3+ will work.
Full Specs
Helios EVO (Main):
Delta - Laptop
4. SSD?
I was told that stock coolers were pretty bad and that i should buy a cooler for the cpu, but im a novice on computer matters so im down to learn, whats your take on this?
THanks for taking time to respond man
The stock cooler on the R5 1600 is great, and it can even handle a decent overclock, unlike Intel units.
Full Specs
Helios EVO (Main):
Delta - Laptop
for intel cpus you would be right. amd did a really good job with stock coolers on ryzen. they are equivalent to like a cheaper 30 dollar air cooler which is pretty decent.
13 minutes ago, merlain10 said:
Decided to go for a Evga GQ 650w 80 plus Gold fan silent Modular
Thanks alot my friend!
There's a good unit.
Full Specs
Helios EVO (Main):
Delta - Laptop
One last doubt about the hdd and sdd, should i buy both units? In case of only buying one, sdd is better right? Im still not sure how they work, been reading but i cant completely understand.
Buy both. The SSD is a lot faster, will make your system feel snappy for a long time but is only available in small capacities. The hard drive is slow but large capacities are cheap. So buy both.
Full Specs
Helios EVO (Main):
Delta - Laptop
You want an ssd for your operating system so that your computer runs fast. You want a hdd for mass storage of large file size items like games.
Just now, IntelFanBoy911 said:
I'm sorry I can't help you, your a lost cause because your using Ryzen
Full Specs
Helios EVO (Main):
Delta - Laptop
Just now, JDE said:
A couple kids found the internet and think they are "cool"
Just report them so we can be gone with their ilk.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
