I need help with my HDD now!!
Rexam
[ SOLVED ]
when i turned on my computer today the WD blue 500gb hard drive was pretty much gone, when i try to open it, it just give me a message that tells me that i need to format it. and it has over 400gb of games on it, and no backup...
post-23396-0-17540800-1386373644_thumb.p
Any advice?? [ SOLVED ]
i7-5930K | Asus Rampage V Extreme | Crucial DDR4 4x4gb 2400MHz | Gigabyte 780 Windforce | Define R4 | XFX 1250w | Samsung EVO500gb
Any advice??
http://www.cgsecurity.org/wiki/TestDisk
get another drive
copy steamapps folder to the new drive
format the old drive
500gb is not much space
do this using ubuntu put it on a flash drive and boot to it get in copy the files over and format the drive if windows wont let you
its the quick and easy way to do anything windows wont let you do
 http://www.ubuntu.com/
well im running the program, but its taking for ever.. i hope it works
Well copying 500GB of data isn't exactly the quickest process ever, especially from a bad drive. :P
Let me know how it goes in the end.
Well, my hard drive was pretty much dead, so i had to format it.And I just replaced it with a WD 2tb black drive i bought from a friend :D
Did you get the data off or did it not work?
Nope :(( but all my games was from steam, other than euro truck sim 2 and wow..
