HUGE performance problems on Gaming PC
Thank you to everyone who made suggestions and tried to help.
As it turns out, the MSI Gaming 7 board is known to be faulty. Once I knew exactly what fault to search for, it opened a can of worms...
The fault means that the motherboard will throttle the CPU "thinking" it is overheating, when it really isn't. This means that the smallest increase in core temperature will cause the motherboard to freak out and throttle the CPU down to 20% capacity.
And there is no solution for it. Many people experiencing this problem simply end up returning the faulty boards to the manufacturer. But since I've had this board for over 2 years now, I am not sure if I have that option.
So now I am on the hunt for a replacement board (NOT MSI) and it is a challenge considering I am looking for a LGA1150 board, which seems to be a scarcity these days...
