Need Compatability Review and Input
Solved by DailyProcrastinator,
3 minutes ago, dogetorhue said:if you're going for budget, don't get a 7700k. I'd recommend a 7600k or even a cheaper i5, but also you should probably go for a 200 seried motherboard (z170 is older and doesn't support all features of kaby lake.
What truly beneficial features does a Z270 motherboard have over a Z170? I had a high-end Asus Z170 board that had more features than any board I have had since, minus a stupid RGB header.
@DDeathlonger That system will provide very good gaming performance and all those parts are compatible. I think it is a fair price, not a crazy good deal but it is fair.
