Can't connect to the internet - Impossible problem?
loPro
While rendering a video a couple of days ago, windows froze up. Ethernet wasn't hooked up to the router. I tried to shut down but it wouldn't so I long pressed the power button.
I tried connecting to the internet last night and it kept giving me limited connectivity. I have two hard drives, one with Win8 and another with Win10. Initially I tried connecting the ethernet cable to my second router. Same error. Then I tried changing the ethernet cable itself. Same error. I swapped Win10 (which I was using) for Win8 and got the same error. Installed windows on a fresh HDD, same error. I keep getting ethernet doesn't have a valid ip adderss or default gateway is not available. I checked the router's DHCP page and the the pc won't show up. Even after giving the mac address a static IP. I tried flashing the bios, still nothing. I tried several CMD commands and obviously reinstalling my drivers. I tried the reset network option in windows 10.
What do I do now?
Did you give the computer a static IP from within Windows itself?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Yes. Took the Mac address, put it in the router's DHCP and made sure the ethernet connection on the PC has the correct default gateway, IP and DNS.
PS: It says Intel(R) Ethernet connection (2) I218-V
Was there a (1)?
Just now, CUDA_Cores said:
But if you can't connect to the internet, how are you here...
From my laptop..
nvm omg it worked
THERE IS A GOD
I reinstalled the drivers again and cleared the cmos. Apparently reflashing the bios along doesn't do jack.
I'M SO HAPPY
