Hi Friends, How are you?
Need your help friends for my new Budget PC Build. I have selected some parts. Need your opinion. My budget is $600 ( Indian Rupee 40k )
Processor : Intel i5-8400 or AMD RYZEN 5 - 1500X
Motherboard : Intel - Asus PRIME-Z370-P or AMD - Asus PRIME B350-PLUS, (optional pick for amd mobo - Asus PRIME B350 F Gaming )
Ram : Crucial Ballistix 2400mhz 8gb single stick
PSU : Corsiar VS550 watt
Note : All ready got 1TB Hdd and I dont budget to get new graphic card ( I have Radeon R7 200 series card ). Im going to use this new pc for gaming and for working in photoshop and little bit video editing. Im indent to use this new pc several year. Got no budget for frequent change. My current pc was bought on 2010 feature Core 2 duo. So you can guess my situation
Please share your opinion on above mention specs. Tell which processor will be suitable for my workload
Thanks
https://linustechtips.com/topic/844325-help-for-midrange-pc-build/
Both R5 and 8400 should work pretty well, although AMD mobos might be cheaper.
Also, highly recommend getting an SSD for the OS, even if it's a small one.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
If you're going intel, don't get a Z series board for a locked CPU. it's a waste since you can't OC anyways with an non-K CPU.
get a PSU that's not a bomb - try the Corsair CX450
other than that, it seems mostly good.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Get rid of the PSU
You don't have a choice with LGA1151-v2 with not getting a Z370 board
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Just now, JDE said:
Get rid of the PSU
Oh, yeah forgot about that little detail...
in that case grabbing a Ryzen 1600 would probably be cheaper. go for that. (since the 8400 will beat the 1500X hands down)
Laptop:
get ryzen, next time you feel like putting money into your pc you can just upgrade the cpu and get more performance (E: because amd is making am4 cpus until 2020). From what I hear z370 is only going to support one generation of cpus
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
On 10/9/2017 at 9:38 AM, JDE said:
Get rid of the PSU
On 10/9/2017 at 9:59 AM, Brooksie359 said:
if the option is between the i5 8400 and the 1500x i would get the 8400. I would get the 1600 if I was going amd though.
Thank you everyone for your kind response.
@Brooksie359 I decided to invest my money on ryzen 1600. Thank you for your reply
@Cyracus Thanks for info. I decided to go with Ryzen 1600 and my motherboard option is Gigabyte GA-AB350-GAMING 3 AMD. Is this mobo fine. There are some less price mobo but this one has more SATA port and USB port. So I selected this. What is ur option?
this is probably worth a look over
desktop
HTPC
