I recently got a master liquid 240mm aio on sale for 65$, when it came I looked at it closely and say bent fins, I knew that was ok since they bend very easily, but I also noticed this little dent on what I'm assuming liquid goes through, I'm not sure if this small dent can turn into a leak or not, I won't use this aio for another few weeks or so as I'm waiting for money for the rest of my parts. Sorry for iPhone quality, this is the only dent I could see on the radiator.
https://linustechtips.com/topic/843923-small-dent-in-aio/
Yeah that's dented the tubes, while it doesn't look like it pierced it ask for a refund or RMA the unit.
https://linustechtips.com/topic/843923-small-dent-in-aio/#findComment-10529955
you're fine. if it's not already leaking it won't start for no reason
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/843923-small-dent-in-aio/#findComment-10529958
Just now, Lucky5 said:
I just discovered a 2nd dented tube, but it's not as deep as the one shown in the pictures, I have a question though, how do most aio's leak? from tubes, pump, or radiator
Hard to say since it varies, but usually a hose connection or the block itself is common as those are the places with seals unless one pokes a hole in the rad or tube.
https://linustechtips.com/topic/843923-small-dent-in-aio/#findComment-10529975
2 minutes ago, Lucky5 said:
so the tube or the block are the more likely spots for a leak?
Generally speaking, yep. My last H115i developed a teeeeeny tiny leak at the tubes meeting the radiator, and even though it was nothing serious I was able to get an RMA. You could probably get an RMA and have some peace of mind.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/843923-small-dent-in-aio/#findComment-10529989
