What is considered high temps in Water Cooling?
Go to solution Solved by Valkyrie Lenneth,
3 minutes ago, Novabutter said:
Small FFT
then the temps are fine man, this is about as good ud get from the aio in that case :v
however the idle temps still seem high, are u sure the cpu isnt randomly beeing stressed while beeing idle? ( tat could explain it tbh )
if prime95 small fft peaks on 60, that means its not an uneven mount ( eventhough that can happen to everyone it goes straight to the 80-100*C on stock, usually 100*C instantly  on uneven mounts hehe )
dont expect too much from an AIO, thats all im saying... ul be dissapointed if u expect alot from a aio
if u want better performance id go for a noctua nh-d15 ( 3fan ofc ) or custom water hehe
other then that id just recommend u to deal with it :v
i wouldnt worry too much about oc with a 1600x btw, u got plenty of cores there and probably the frequency ul end up getting is like 4ghz/4.2 at most or smt (due to ur temps)
3 minutes ago, Valkyrie Lenneth said:
for prime95 small fft ( depending wether my voltage goes extreme or not )
with no extreme voltage i usually peak to 90-93*C ( as my border of acceptable basicly 90 )
80 is quite normal for oc, thats my exact temp right now in my current oc on my 4690k @ small fft :)
at 80*C i still push it somtimes haha,
while prime95 small fft runs it really is the max temp possible and u wont even get near that temps in gaming ect, if its like 85-90*C with small fft, with gaming its prolly gonna end up in the 60-70*C range
since max temp on ur chip is 95*C i would just stick with 90*C max temp @ SMALL FFT mode :)
unless ur voltage is extremely high ( i doubt u can even reach extreme high voltages on ur cooling solution tbh )
basicly short said i think ur fine till 90*C
remember even if ur cpu pops to 100*C doesnt mean it will damage instantly, it will take weeks/months to damage it , just not recommend to go above 90*C for extended periods
That works. Thanks a ton. Now onto why the f*** ASUS Aura is so jacked up all the time....
i dont even know what that is, i dont use any software / motherboard features hehe
i usually build my stuff and extremely tweak my windows, use as little software crap as possible, if its not a driver i basicly dont install it xD
also
for temp/monitor i recommend u
CPU-Z
HWMONITOR
both from the company CPUID :)
I'm always having to go grab older versions and install those. Asus is usually on point, I wonder why they still don't have a stable rgb control software.
Intel i7-7700k @ 5.1ghz | Asus ROG Maximus Hero IX | Asus ROG Poseidon Platinum 1080ti @ 2126mhz | 64gb Trident-Z DDR4 @ 3600mhz | Samsung 960 Pro 1tb @ 3500mbps/2500mbps | Crucial 240gb SSD | Toshiba 4tb 7200rpm HDD w/ Crucial 128gb SSD cache | Corsair Hx1000i PSU | EK 360mm Coolstream XE Radiator | EK-Supremacy Evo Waterblock | EK-DDC 3.2 PWM Elite Edition Pump | EK-RES X3 150 RGB Reservoir | Primochill AdvancedLRT Clear Tubing | Primochill VUE UV Blue Coolant | Corsair 570x Crystal RGB Case | 4x 30cm CableMod UV/RGB Widebeam Hybrid Led Strip | 3x 120mm Corsair SP120 RGB Fans | 3x Noctua NF-A14 iPPC 3000rpm Fans | 3x Noctua NF-A12x15 Fan | CableMod ModFlex PSU & SATA Cables | Asus ROG Swift 27" 4k IPS w/G-Sync & LG UD68 27" 4k IPS w/Freesync |
Prolly user error. Assuming the hardware is performing as intended. Aio isn't watercooling, if it is my titans came stock with water coolers years ago.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
