1600x cooling What is considered high temps in Water Cooling?
3 minutes ago, Novabutter said:Small FFT
then the temps are fine man, this is about as good ud get from the aio in that case :v
however the idle temps still seem high, are u sure the cpu isnt randomly beeing stressed while beeing idle? ( tat could explain it tbh )
if prime95 small fft peaks on 60, that means its not an uneven mount ( eventhough that can happen to everyone it goes straight to the 80-100*C on stock, usually 100*C instantly on uneven mounts hehe )
dont expect too much from an AIO, thats all im saying... ul be dissapointed if u expect alot from a aio
if u want better performance id go for a noctua nh-d15 ( 3fan ofc ) or custom water hehe
other then that id just recommend u to deal with it :v
i wouldnt worry too much about oc with a 1600x btw, u got plenty of cores there and probably the frequency ul end up getting is like 4ghz/4.2 at most or smt (due to ur temps)
