Alright, so, here's the deal. I recently built a rig with a LC power 600w v2.31 power supply. Yesterday, I noticed a very high pitched sound coming from the supply when the PC is off and the PSU is plugged in and turned on. Read online that it could be a sign of its lifespan ending (it was bought a bit more than a month ago -.-) or coil whine. Either way, I plan to return it and get a better one, but preferably for a similar amount of money.
My rig is:
Gigabyte GA B250 - HD3P motherboard
Intel i5 7400 3.00GHz CPU
Zotac GTX 1050 ti 4 GB OC edition GPU
8 gigs of Kingston Fury HyperX DDR4 2400MHz RAM
1 TB WD Purple 7200 RPM 64MB HDD
I plan on adding an optical drive and a wifi card some time soon.
The question is, what power supply do you recommend priced at around 40-50 euros (which I know isn't a lot, but I can't go any higher)?
Thanks! :)
Intel i5 7400 3.00 GHz
Zotac Gtx 1050 ti 4 gb OC
8 gb Kingston Fury HyperX DDR4
1 TB Western Digital Purple HDD
https://linustechtips.com/topic/837852-looking-for-a-power-supply/
7 minutes ago, deXxterlab97 said:
Corsair CX 450 I checked on tweakers.net is around 47 euros. Very good unit
https://tweakers.net/pricewatch/745437/corsair-cx450/specificaties/
So you think 450 watts is enough for this build? (+ full HD monitor)
Yes. You're talking less than 150W for total system power consumption.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
3 hours ago, Jaga848 said:
Okay, I'll wait to see some more suggestions. Thanks for all the input so far! :)
The other suggestions are just going to tell you to get a CX450, just BTW. Or, if it's available in the location you're in, the Corsair Vengeance.
So the Corsair CX450 is definitely a good choice? Any difference between the CX450 and CX450M, except from the latter being modular?
no, a good 300W would be more than plenty.
Problem:
There ain't no good 300W at the moment so he had to recommend a 450W...
"Hell is full of good meanings, but Heaven is full of good works"
