Razer Blade heat troubles
Solved by pbhenry3,
good advice above mostly. All you can really do is
1. repaste with something like gelid gc extreme, which if you do this, mine as well put new thermal pads on as well such as fujipoly ultra extreme.
2. undervolting-perhaps the simplest method to try first. throttlestop works quite well for this and you can set it to start with windows through "task scheduler". the 6700hq should have no problem with -125mV offset.
thats about it. unless you want lower temps at the cost of lower performance in which case you could change window power plan settings to utilize less than 100% max cpu performance, which would basically just disable the turbo boost.
