In need of a CPU cooler
Wobblyyyy
In need of a CPU cooler that meets these requirements:
At least 49 mm RAM clearance
Doesn't block first PCI-E slot
Can cool an i7-7700k very well
Can fit in a H440 from NZXT
Going air cooling - no water coolers please.
Thanks
Just now, Himommies said:
Budget?
None. Well, something reasonable. Under $120 if possible.
Noctua NH D-15
My life
Noctua NH D-15
From what I've read, it doesn't have enough RAM clearance?
Oh yeah.49 MM is really talI would really recommend a AIO at that point otherwise the NH-U14 is a good idea
My life
Okay - Any water-coolers you'd suggest? (sorry for so many questions)
H100i V2 or the Kraken X62.Pretty much the only one's I would reccomed. The only difference between the 2 is the X62 being a 280mm cooler so it's like 2-3 degrees better and RGB
My life
if you can find one on the cheap, bequiet dark rocks are great :D you do slice open your fingers trying to mount them tho..
otherwise, how much -if at all- are you planning to OC that 7700k? because you cant quite beat the clearance of a D9L :P
What about an AIO cooler?
edit :saw you want air cooling ... will check back in a minute.
EDIT2: NHd15 ? That has some RAM clearance . And depending on the orientation , you'll have enough space for PCIE cards.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
