Mp Monitor setup 1080p/4k monitor
Matt_Allensy
I have a 4k monitor as my main one and then 1080p monitors to the side. Does this downscale the resolution for the 4k to 1080p if I have the two hooked up?
"Look at me I'm a Target"- The Eleventh
No, not unless you do Surround or Eyefinity. They are all independent. If your GPU can support it then they should all be native resolutions. Windows probably does window scaling so they look the same size but its probably full 4k
Specs:
 Gaming PC: i5 3570, 16GB 1600MHz, GTX 780 3GB, Transcend 128GB, WD 500GB, Seagate 500GB, Thermaltake 600W Smart, S340 w/ RGB, Windows 10 Pro
 Server: Xeon E5 2650, 12GB 1600MHz ECC, 8400GS, WD 2TB + 1TB + 1TB, EVGA 500B 500W, Windows 10 Pro
 Laptop: Macbook Pro Retina 2013, i7 4558U, 8GB 1600MHz, Intel Iris Pro 1.5GB, Apple 256GB NVME, Mojave
 Internet: $70/month For 500/100, Actually get 525/102
