What rails does linus use?
Solved by Jarsky,
It doesn't matter what Linus uses. You're using different cabinets and different chassis.
There are a huge array of universal fit, fixed and sliding rail kits. As pointed out though you'll need to make sure your rails are adjustable to the depth of the cabinet you're mounting them into. Most rail kits are length adjustable.
For my 1U Norco chassis i have a Norco RL-26 rail kit.
Since you're looking to use a heavier 4U chassis, you might want to check out the Norco RL-20 rail kit. Theyre extendable up to 32" deep cages
So this here: https://www.newegg.com/Product/Product.aspx?Item=N82E16811997302
