Dry ice on 4690k
No sure if this is a really bad idea but, I want to see what max frequency I can get on my 4690k, I have a Corsair h115i, could I put the RAD in a bucket and then fill the bucket with water and then drop dry ice into the water,
Im worried about the coolent freezing, im not sure what the chemical proporties ofthe coolent they use is
| CPU Intel I7 6700K | Motherboard Asus ROG Maximus VIII Hero | RAM 16GB Corsair Vengeance LED 2666Mhz | GPU MSI GTX 1080 Ti Gaming X + NZXT Kraken g12 w/ NZXT Kraken x52 | Case NZXT h440 | Storage 500GB Samsung 960 Evo, 2TB Samsung 850 Evo | PSU EVGA Supernova G2 750W | Cooling Thermaltake Water 3.0 Ultimate |
I think it would be a better idea to either delid or use liquid nitrogen.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
the chip is already delided and I plan to get into dry ice and LN2 OC eventually, this is just sort of a segway into that
4690ks were soldered i believe
nope, ive already delided it sooooo
i see, i wouldnt do your idea probably not worth it, get a custom loop going if you want lower temps
Its not for 24/7 use, obv an aio in a bucket is not practicall for 24/7. I want to do it to try to get HW points
Why the fuck would you do this lol... Water dissipation with a rad is awful on it own, Bitwit (Awesomesauce at the time) did a video on having a rad in an ice bath, and it quickly showed that it wasnt worth it. The rad simply was not designed to do this, so its a terrible idea.
They probably use some ethylene glycol based coolant in the AIO.  Condensation is always *the* problem when running subambient water.
Workstation:  14700nonk || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 9900nonK || Gigabyte Z390 Master || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3080Ti Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
