1 minute ago, Azriel said:
No I ONLY need a new CPU, GPU, RAM, and mobo.
that is a cpu
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Just now, Homeless_Pineapple said:
For those who are quickly looking through your post looking for a PCPartPicker list, people might miss this. I'm not saying that you didn't explain it, but you will receive more useful answers if your part list makes it look like you only need four components.
Now that we all should know that I only need four components, can we please get into finding the best four components  eight hundred dollars can buy?
4770K
reuse your mobo
get more ram
gtx 1070 or 1080
Full Specs
Helios EVO (Main):
Delta - Laptop
31 minutes ago, Azriel said:
Would anyone be able to help me with a build that's around $800, preferably under. I do have a Hyper Evo 212 cooler but I'm not sure if I should get a new one since the buy needs to include a motherboard, RAM, CPU, and GPU. Put the best ~$800 can buy :). Thanks much!
This is my current build that's around 800$
https://pcpartpicker.com/list/DGJYD8
"Needs to include" is not the same as "only has to include"
Besides, when you said "my current build" I thought this is what you already have and using, and I'm like "how can this guy use a PC without any storage"
Desktop benching:
Why would I buy an i7 when it's not budget friend when it comes to price-performance.
They sell for like $120 used
Full Specs
Helios EVO (Main):
Delta - Laptop
Once again, make your part list clearly show your intentions. You'll get initial confusion by posters. Your part list is incomplete, so many posters will attempt to fill in your missing components. Posting an incompatible or incomplete part list is bad practice.
It would be useful if you could explain whether or not you are willing to keep old components and get a CPU upgrade.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
But you can reuse the mobo and RAM in this case. A used 4770k/4790k is also cheaper than a new R5 1600 CPU. I would seriously consider an i7 unless you don't want to buy used parts. The saved budget could allow a GTX 1080 and a new monitor
Edited by Jurrunio
Blackened edited area
Desktop benching:
The list in his personal profile is actually quite complete
Desktop benching:
I noticed as much, though I still believe posting incomplete part lists is bad practice. It leaves a great opportunity for confusion.
Desktop
Homelab
That you for actually looking! I have a rig but the four parts that I listen need to be replaced. I mean at this point I think that the pcpartpicker list that I pasted is better that the trash ideas that most sent. I do not want to reuse any parts otherwise I would. I wish people would just help me with the four parts I need. Thanks once again dude!
I take it that you are not willing to consider upgrading to another CPU in the chipset you already own?
Desktop
Homelab
Yeah I'll take note of that. Though like I said you know the parts and if you want to help please. If you want to keep complaining about my mistakes that I've corrected, it's up to you.
Dude what's so hard to understand about just making a build with four parts. Forget about any idea about the build that doesn't include buying a new CPU, GPU, RAM, and mobo. I do not want to reuse, buy a case, or any other thing besides buying new.
I'm unsure why you're replying to my same comment with two different answers.
Anyways, here is the part list I recommend: https://pcpartpicker.com/list/4wBs3F
I would suggest against getting a 1600X since your 212 EVO will not support the AM4 chipset without an adapter. The R5 1600 comes with a good stock cooler and can be overclocked to perform just as well as the 1600X. Your graphics card looks good, and I'm going to assume that price you manually entered (329.99) is from your local MicroCenter.
Desktop
Homelab
$289 on newegg though
Full Specs
Helios EVO (Main):
Delta - Laptop
I didn't check other prices for the card, I just assumed that was the price he would be paying if he purchased this card. MicroCenter offers Newegg price check anyways.
Desktop
Homelab
I do thank you for your suggestion but if I am not mistaken I think that cooler master has adapters for the AM4 chipset though they may be out of stock.
If you're convinced on going with a 1600X, you can pick up an AM4 bracket from your MicroCenter. They're cheap and in stock at http://www.microcenter.com/product/475708/amd_am4_cpu_cooler_upgrade_kit.
Desktop
Homelab
