Need help with OHMs
HyperPanda
Hey guys so I'm thinking about getting some beyerdynamic dt990 pros and I'm having an issue with OHMs. The best deal is the 250 OHM pro and I'm not sure if I can use it with an iPod. I'll be using them for my laptop and for my iPod so I'm not sure if they can handle them or what. My laptop is macbook air 2013. -Thanks
Most people would would say they are too high for a portable device. More to do with battery life than SQ although for 250ohm you'd notice lower volume levels.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
For 250 Ohms you will need an amp.
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
It won't be very loud.
that said it might depend, I have 990's and they actually get pretty loud connected to my phone.
Error: 410
