Posted August 9, 2017 Hey LinusTechTips comunity, im new here but Linus adressed me here from a video he uploaded about choosing a monitor. I have a EVGA GTX 760 and I have these 4 monitors to choose from: https://www.amazon.com/gp/product/B06ZYHZ6R6/ref=s9_acsd_al_bw_c_x_3_w?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=merchandised-search-2&pf_rd_r=JAC4SP97XX84XWYYFF7Q&pf_rd_r=JAC4SP97XX84XWYYFF7Q&pf_rd_t=101&pf_rd_p=4b9528ec-b76d-4209-a972-2bfd1ce44eae&pf_rd_p=4b9528ec-b76d-4209-a972-2bfd1ce44eae&pf_rd_i=1292115011 https://www.amazon.com/VG248QE-1920x1080-144Hz-Gaming-Monitor/dp/B00B2HH7G0/ref=pd_sbs_147_2?_encoding=UTF8&pd_rd_i=B00B2HH7G0&pd_rd_r=QNG13R6FMW954W52WRB1&pd_rd_w=cnRDn&pd_rd_wg=rVq5I&psc=1&refRID=QNG13R6FMW954W52WRB1 https://www.amazon.com/AOC-G2460PF-24-Inch-Professional-Monitor/dp/B01BV1XBEI/ref=pd_sbs_147_3?_encoding=UTF8&pd_rd_i=B01BV1XBEI&pd_rd_r=6GJAZXV4B2A41EN1GTVA&pd_rd_w=NSsg8&pd_rd_wg=4jmsX&psc=1&refRID=6GJAZXV4B2A41EN1GTVA https://www.amazon.com/Acer-GN246HL-Bbid-24-Inch-Display/dp/B00KO4518I/ref=pd_sbs_147_1?_encoding=UTF8&pd_rd_i=B00KO4518I&pd_rd_r=6GJAZXV4B2A41EN1GTVA&pd_rd_w=NSsg8&pd_rd_wg=4jmsX&psc=1&refRID=6GJAZXV4B2A41EN1GTVA Help is much appreciated! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 Why 144hz my 770 cant max games out you would have to lower the settings but why go with something that you really dont need Im mostly on discord now and you can find me on my profile My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 Definitely not three because is free sync and you will be using g-sync, you might want upgrade GPU to Quote "(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr https://myanimelist.net/profile/AnalCavity PCPartPicker URL https://pcpartpicker.com/b/bsJ8TW Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 Every monitor is 1080p, 144 Hz, and has good reviews. AMD FreeSync is useless in your case. I would go for the Acer GN246HL 3D monitor, it might be fun to play around with 3D, and it's cheapest because of some reason EDIT: Although it doesn't have shitty monitor speakers, if you are into that kind of thing Long live Stalin, he loves you; sing these words, or you know what he’ll do! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 3 minutes ago, Billy_Mays said: Why 144hz my 770 cant max games out you would have to lower the settings but why go with something that you really dont need CSGO should run over 200 FPS if his CPU is decent Long live Stalin, he loves you; sing these words, or you know what he’ll do! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 2 minutes ago, noisebomb44 said: CSGO should run over 200 FPS if his CPU is decent Thats ok and my FX 6300 its an ok CPU and I go between 90-170 fps but depends on the map Im mostly on discord now and you can find me on my profile My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 i would get a new GPU. 760 is not pushing many games at 144fps to take advantage of the refresh rate. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 edit: im dumb lol Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 4 minutes ago, yodaobiwan1 said: if i were you, i would buy an older used desktop (you will need a mini tower size) and swap in the gpu, psu and ram you currently have. some examples of this kind of pc from ebay: http://www.ebay.com/itm/Dell-OptiPlex-790-Mini-Tower-3-30GHz-Core-i5-4gb-DDR3-320gb-DVD-ROM-/132289033545?epid=219528940&hash=item1ecd0a7549:g:fJQAAOSwzRlZihJJ this ones nice cause it comes with a gpu in it already, you can probably find a better deal anyway that doesnt have a gpu. comparison- http://cpu.userbenchmark.com/Compare/Intel-Core-i5-2500-vs-AMD-FX-6300/m517vs1555 edit: also you should probably get a better gpu as mentioned before I dont need to upgrade right now and that would be another OEM system taking up space and Im fine for now and I know the i5 2500 is better but Im going to upgrade to ryzen soon plus I am pretty sure that the dell system needs a specific PSU so I dont want to spend more money on a system that I dont need Im mostly on discord now and you can find me on my profile My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 Just now, Billy_Mays said: I dont need to upgrade right now and that would be another OEM system taking up space and Im fine for now and I know the i5 2500 is better but Im going to upgrade to ryzen soon plus I am pretty sure that the dell system needs a specific PSU so I dont want to spend more money on a system that I dont need yeah my bad i was too quick and thought you were op Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 Just now, yodaobiwan1 said: yeah my bad i was too quick and thought you were op Oh ok its fine Im mostly on discord now and you can find me on my profile My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 Author Thank you all for the replies! Eventually I will upgrade my GPU, and I understand I wont make the most of 144hz with mu current GPU. But nontheless I still want to have a good monitor for when I upgrade my GPU. Based on Noisebomb44's comment I could go for his suggestion? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2017 Author NVM Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
