Should I keep this build or switch it to Ryzen?
Solved by mrBostonTech,
3 minutes ago, xDyl said:Also the ROG screen is the same as the 27" predator on newegg. Which one should I go with then? Or should I just use 60Hz because I don't really want to spend all my money towards the monitor.
ROG is slightly better 165Hz to 144hz. Having a 1080ti pretty much required 144hz gaming monitor and it's kinda ugly not to have one with this GC. The frames will be much smoother and overall gaming experience will be better. Whatever you decide just make sure your monitor will have at least G-Sync
