Just now, deXxterlab97 said:
850w is fine
EVGA G2/G3/P2/T2/PS
Seasonic Prime/Focus/X series
Corsair RMi/RMx/HX(new)/AX,AXi
Cooler Master V (modular)
Bitfenix Whisper M
SuperFlower - Leadex Gold/Plat/Titan
7 minutes ago, URANIUM X said:
1Going to build a pc a week later
Here is my list:
Ryzen 7 1700X
32gb ddr4 3200mhz
Crosshair vi hero
Asus strix 1080Ti x2
500gb ssd
4tb hdd
+a few rgb fans and rgb light strips
How much voltage do I need for that?
Is 1000w enough for my build?
Which psu should I get?
Yes 850w is fine it's around 700w on normal usage.
https://linustechtips.com/topic/815302-how-much-do-i-need/#findComment-10227422
I have 2 Maxwell TITAN X running on 850w just fine, no need for 1000w if you're sticking to just 1 HDD.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/815302-how-much-do-i-need/#findComment-10227429
Here is my list:
Ryzen 7 1700X
32gb ddr4 3200mhz
Crosshair vi hero
500gb ssd
4tb hdd
IMO i do not reccomend SLI, for what do you want the 2nd card for? What is the use case for this system?
https://linustechtips.com/topic/815302-how-much-do-i-need/#findComment-10227446
important question.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/815302-how-much-do-i-need/#findComment-10227461
Here is my list:
Ryzen 7 1700X
32gb ddr4 3200mhz
Crosshair vi hero
500gb ssd
4tb hdd
1000W is enough and is what I would personally get for a dual 1080 Ti system if I wanted to overclock. That said, what are you buying two GPUs for? 4K 144Hz or something? What 1000W units are you looking at?
https://linustechtips.com/topic/815302-how-much-do-i-need/#findComment-10228322
250w for the GPU, 100W for the CPU, maybe 20W for the MB/HDD/RAM?
you'd throw 1000W at that? puh-lease...
did not see dual. that's probably just right for efficiency.
System specs:
https://linustechtips.com/topic/815302-how-much-do-i-need/#findComment-10228338
Get 1k as you won't be riding the limit. Also won't have to hear the psu fan as much.
Id get corsair first then evga. Depends on the quality of the sleeved at that point.
https://linustechtips.com/topic/815302-how-much-do-i-need/#findComment-10233281
16 hours ago, URANIUM X said:
which psu is better
Cooler master 1000v
Corsair AX1000i
Evga supernova 1000 P2
Depending on budget i would look into getting a Seasonic PRIME Titanium 1kW, failing that, a Corsair AX1000i would probably be the best choice, although all three of those units are great.
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
https://linustechtips.com/topic/815302-how-much-do-i-need/#findComment-10235988
