Just moved all my components over into a new case and my Liquid cooler GPU is running at 73 degrees. Before it was at about 65 degrees max.
I'm pretty sure I installed everything correctly, especially made sure the Radiator fan is the right way around. What else could cause this?
My other R9 290 is still running fine (stock cooler) same temps
Corsair h55 with Corsair Bracket for R9 290.
Ryzen 7600X | MSI Trio X 3080 | 3440x1440p asus vg34vql1b | Antec HCG 850 | 1TB WD Blue SSD | 500GB Aorus Elite | Asus B650 Strix A
https://linustechtips.com/topic/814859-high-temps-on-liquid-cooled-gpu/
Different airflow in the new case?
Proper application of thermal paste?
Anyways, 73 degrees are nothing to really worry about, well within reason.
Hope I said anything helpful!
Case: Corsair Graphite 760T || PSU: Corsair RM650i || Mobo: Asus RoG Strix Z270E || CPU: Intel i5-7600K @4.8GHz || Cooler: Corsair H110i v2 || RAM: Corsair Vengeance DDR4 3200MHz 16GB White LED || GPU: MSI GTX 1070 8GB GAMING X || SSD: Samsung 850 Evo 250GB, Samsung 860 Evo 500GB, Samsung MZ1280 M.2 128GB || HDD: Seagate Barracuda 1TB
This case has better airflow, that's why I chose it.
What application of thermal paste? I installed my GPU into another PC, there's no thermal paste involved in that
Oh, I missread, sorry! My eyes saw GPU, but my mind saw CPU!
My bad
You might have to take it apart and redo the paste. If it has been used for a while the paste may have dried out a but and moving the GPU could have broken the contact. It's a good idea to replace thermal paste every once in a while (maybe once a year depending on use and paste quality) to refresh it and give better heat transfer.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
Mount most likely. Prolly came loose or hoses are tight enough to pull the mount a little.
14 hours ago, Internet Swag said:
I also feel it is the mount. I believe Jayztwocents did a video where he found that some plastic was interfering or something like that
I would expect the water to perform much better than 70's.
