fps issues
Coltonw023456
ok so i cant run games in windows mode with out shuttering alot and my games shuttering and fps issue mostly fps issues so if some one can help me i will love that
What games/res? Why are you running in windowed mode?
Nice wallpaper, BTW.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
thanks and gta 5 and garry's mod i need to use windows mode to stream gta5 and my other games the stream will not pick up fullscreen
and you have someing we can talk on and :)
What are you using to record it? i use ShadowPlay for Battlefront II (you should play it, it's still an awesome game). i used to run it windowed since the game Bar can't detect it in fullscreen, but ShadowPlay works fine.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
well i do younow and do you have dicord or skype?
I've got discord. I can PM you a link to our chat. It's got me, @WhisperingKnickers, his roommate, and @LooneyJuice so far.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
its because the gpu has to render the desktop + program in windowed mode
sometimes the stutter is normal because the gpu has to drive different surfaces on one screen
3x 128GB Samsung PM961 M.2 (2x Kryom PCI-E M.2 by Aqua Computer) on windows os raid and 1x PM961 as os Host on the motherboard m.2 slot
+ 250GB Samsung 850 EVO
+ 7200RPM Seagate 1 Terabyte HDD
  • PSU
    seasonic 750 prime platinum Active PFC F3
  • Cooling
    Noctua NH-D15S (original fan replaced by an Noctua 140mm industrialPPC-2000 IP67 PWM + Steel 140mm fan guard)
  • Keyboard
    Cherry MX Board 6.0 ISOANSI + Vector/Tai keycaps+ Landing pads + O-rings
  • Mouse
    BenQ Zowie EC2-A White Edition
  • Sound
    Edirol Roland UA-25EX + Beyerdynamic DT 770 Pro
  • Operating System
    Windows 10 x64 (Enterprise) SP1, OpenSUSE, Remnux
well do you have a Intel® Xeon® Processor
ok cool lets to it
PM sent.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
well i got a shity cpu
mine is shitty too : )
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
but if you want to stream and game a pretty demanding game
Your cpu is your bottleneck
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
its not overing the temps
4 cores for gta v+ obs + stream
your cpu is the bottleneck
dont confuse it for gpu bottlenecking
your software is bottlenecked by your hardware (in this case your cpu core count)
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
well it shutters and fps issues wan im not streaming so
get a i7
  • PSU
  • Cooling
  • Keyboard
  • Mouse
  • Sound
  • Operating System
get a i7
i dont have money man and gefore and evga said i can run it
My CPU is shitty too,for well what I do at least
My life
you do what ?
8 threads though and it's just GTA V+OBS obs is streaming
Try streaming at a lower resoloution such as 720 and see how that works
My life
you do what ?
Audio Engineering.But that's irrelavant kindof.
My life
oh and wan i play gta 5 my audio cuts out alot some times
