What's a good cpu air cooler?
JoshPJ
I don't really have a budget and im looking for an air cooler that isnt very loud and is decent for overclocking, here is my build: https://uk.pcpartpicker.com/list/x86Tcc
Edit: it's my first build but I could go with a liquid cooler if that would be better
CPU: Ryzen 3700X Motherboard: Gigabyte X570 Pro Wifi CPU Cooler: NZXT Kraken x62 Rev 2 RAM: 16GB Corsair Vengeance DDR4 3000Mhz GPU: Asus TUF OC RTX 3080 SSD: 250GB SK Hynix SATA and 2x 1TB Samsung 980 Pro M.2 PSU: Corsair SF750 Case: Cooler Master NR200 Monitor: LG 27GL850 Keyboard: Logitech G810 Orion Spectrum Mouse: Razer Viper Audio: Sennheiser PC37X and Logitech G560 Speakers
Just now, Ricardo56 said:
Noctua seems to get a lot of praise but I don't know a lot about fans and stuff
haha thanks
4 minutes ago, James_Lutzke said:
Hyper 212 Evo
is the hyper 212 led turbo as good because it comes with the am4 bracket out the box
Just now, James_Lutzke said:
im from UK so I will have to find the UK version, is liquid cooling worth it?
I don't have a Ryzen CPU so I have no clue what temps they run at. If you are planning on overclocking, an AIO liquid cooler might not be a bad idea.
ok thanks, i will make another topic on it
I am very happy with my be quiet dark rock 3 (running on an R7 1700). Had to order an AM4 bracket, but had it within a week.
where did you get the bracket?
Got it from be quiet themselves:
http://www.bequiet.com/en/am4
100% free once you upload your AM4 motherboard invoice.
