Case Fans: GP-14 vs AF140 Quiet
Tech Wizard
Hello team,
I'm rocking a Define R5 (which came with 2x GP-14s), and I have installed both as front intake, and bought an AF140 LED Quiet for rear exhaust. The GP-14s in the front is making some weird buzzing sounds, which is starting to get slightly annoying. Noticed Corsair's AF140s Quiet edition are 35 % off in Norway, and was thinking of buying 2x and swapping them with the GP-14s. Are they any better than the GP-14s at all, or same? RPM and dBA is slightly higher on the AF140s, and the GP-14s have slightly better CFM, so spesifications-wise the GP-14s wins in all scenarios, but I'm thinking of what the 13 blades in the AF140s can do. What do you guys make out of this? Here's a picture of setup:
Edit: They are going for $15 each.
Main:  1650 v2   @ 4,6GHz   -   X79 Deluxe                -   GTX 1080 @ 2000MHz   -   24GB DDR3 @ 2400MHz / CL10
Side:   i7-4790K @ 4,5GHz   -   Maximus 7 Hero        -   GTX 1070 @ 2114MHz    -  16GB DDR3 @ 2666MHz / CL12
HWBOT
I'd pick up two Noctua NF-F14s for the front since you can't see them and there's restricted airflow at the front.
