Hey guys! Just OCd my 3930k to 4.2GHz (previously it was 4.0GHz) and got these temps. I am using the standard fans that come with the H100i in a push config. Please tell me if they are good or not just to be safe. (4.2GHz Turbo)
http://prntscr.com/278gf9
Main Rig: Intel i7 3930k @4.0GHz---8GB Ballistix @1600MHz---Asus P9X79 Pro---Samsung 840 Pro 128GB---3TB HDD Config---2x GTX 780Ti 3GB---Windows 7 Ultimate
Laptop: Late 2012 13" Retina MacBook Pro---2.5GHz Dual i5---8GB DDR3 @1600MHz---128GB PCI-E SSD---Intel HD4000 1GB---OSX 10.10 Yosemite
Phone: Nexus 4
https://linustechtips.com/topic/81402-h100i-3930k-temps/
They're fine. You can go up to 80 celcius just fine.
You should really be shooting for at least 4.5-4.6 ghz with the h100i.
https://linustechtips.com/topic/81402-h100i-3930k-temps/#findComment-1115014
Not so bad. I'd keep it at somewhere of 70-75 degrees for performance but thats a good overclock :)
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/81402-h100i-3930k-temps/#findComment-1115018
what are you using to test it? i suggest using ibt.
https://linustechtips.com/topic/81402-h100i-3930k-temps/#findComment-1115065
I have my 3930k at 4.5 GHz and it idles around 40 and loads at 72ish on an H100i.  I have one hot core and my room heats up, but I'm reasonably happy with my temperatures.
I think the vcore is the more concerning parameter for a 3930k. These are hot chips no matter how you look at it.  Don't set your vcore above 1.4V, I believe I have mine set at 1.325V, and watch what you set your LLC to (see http://linustechtips.com/main/topic/24019-load-line-calibration-why-overclockers-should-care/).
Isopropyl alcohol is all you need for cleaning CPU's and motherboard components.  No, you don't need [insert cleaning solution here].  -Source: PhD Student, Chemistry
Why overclockers should understand Load-Line Calibration.
ASUS Rampage IV Black Edition || i7 3930k @ 4.5 GHz || 32 GB Corsair Vengeance CL8 || ASUS GTX 780 DCuII || ASUS Xonar Essence STX || XFX PRO 1000W
https://linustechtips.com/topic/81402-h100i-3930k-temps/#findComment-1116428
Actually he can set the core voltage up to 1.5V. Anything above 1.5V is beyond Intel spec and is not recommended, however 1.4-1.45V is pretty ok. I have been running my i7 3820 at 4.8GHz with 1.43V for quite a while now and before that my i7 3930K (RIP. It died because I dropped it :D) at 4.7GHz at 1.425V, so yeah, this kind of voltages will not harm your processor if your temps are below 80C.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/81402-h100i-3930k-temps/#findComment-1117170
...before that my i7 3930K (RIP. It died because I dropped it :D) at 4.7GHz at 1.425V, so yeah, this kind of voltages will not harm your processor if your temps are below 80C.
I guess it depends on who you ask.  Below 1.4V was what I heard while I was doing my OC, so I'm going to stick with that.  Besides, I don't have much thermal headroom anyway, so I won't be pushing it beyond what I have.
https://linustechtips.com/topic/81402-h100i-3930k-temps/#findComment-1121483
