I'm sorry if I'm being an irritation by asking you a crap ton of questions. But I don't where else to go; you're all most likely older than me with more knowledge. My dad is busy at work; and my mom is not good at English, let alone help me on problems including english
I have more than 20 questions from the course of completing practice problems( no it's not homework), so I'll try asking little by little.
For #22, I can't think of an answer other than "angle K is acute and angle MHO is obtuse".
https://linustechtips.com/topic/809762-need-more-help-related-to-math/
You need to show the image, which contains the rest of the info, for anyone to help you. Otherwise we're missing information and it's unsolvable.
On 7/19/2017 at 11:29 AM, valdyrgramr said:
Is that image next to it part of the problem?  If so then you might wanna show that too.  I don't have a lot of time, but that would be useful info for us.  Otherwise, not enough information to solve or help too much.
Sorry.
that looks a lot like homework
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
I'll avoid a complete answer, but the primary concept you need to use is the fact that bisecting a line means both sides are equal, so the triangles to the left and right of point M have identical dimensions.
"Do as I say, not as I do."
-Because you actually care if it makes sense.
I never liked doing proofs.
There's a few concepts you need to know, though.
Congruent Angles
Supplementary Angles
Complementary Angles
Vertical Angles
Linear Pair
and Adjacent (although don't think I've used this much)
I skipped most of geometry and went straight to trig in college so I'm not entirely skilled with angles and shapes, just triangles. Try using some examples from Khan's Academy. (There's also a mobile app)
Mobo: Z97 MSI Gaming 7 / CPU: i5-4690k@4.5GHz 1.23v / GPU: EVGA GTX 1070 / RAM: 8GB DDR3 1600MHz@CL9 1.5v / PSU: Corsair CX500M / Case: NZXT 410 / Monitor: 1080p IPS Acer R240HY bidx
