Posted July 18, 2017 I'm building a budget gaming pc and I wondering what the best motherboard,ram and gpu would be for this cpu https://www.amazon.co.uk/gp/product/B01BF376EI/ref=ox_sc_act_title_1?smid=A3P5ROKL5A1OLE&psc=1.i would like to overclock the cpu and I will be doing a lot of gaming on this pc. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2017 2 minutes ago, cumbum937 said: I'm building a budget gaming pc and I wondering what the best motherboard,ram and gpu would be for this cpu https://www.amazon.co.uk/gp/product/B01BF376EI/ref=ox_sc_act_title_1?smid=A3P5ROKL5A1OLE&psc=1.i would like to overclock the cpu and I will be doing a lot of gaming on this pc. dont. my brother ran a 760k, its too weak for games of the last years if you want 60fps. I often cant get more than 60fps in BF1 with a i5 4690k 4,7ghz with gtx 1080 ti. save up or maybe you can get at least some used i5 4460 + mobo + 8gb ddr3 combo somewhere on craigslist Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2017 Author imnoth realy going to to be running new games I will be running hoi4, warthunder,h1z1,gta 5 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2017 Author bu tif that cpu is not good enough I would buy the 870k instead if it would be any better Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2017 7 minutes ago, cumbum937 said: bu tif that cpu is not good enough I would buy the 870k instead if it would be any better No. Even 4th gen i3s can beat it in terms of CPU performance. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2017 Author I'm definitely buting this cpu but could u tell me what would be the best ram and motherboard for this cpu Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2017 13 minutes ago, cumbum937 said: I'm definitely buting this cpu but could u tell me what would be the best ram and motherboard for this cpu cheapest you can find with that socket imo Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2017 16 minutes ago, cumbum937 said: I'm definitely buting this cpu but could u tell me what would be the best ram and motherboard for this cpu 8GB DDR3 (2 4gb sticks or a single 8gb stick doesn't matter) Cheapest mobo with the right socket and preferably 4 or more power phases. Of course don't buy boards that are much cheaper than others. Most likely scam posts. Make sure you have a good PSU, CPU cooler too. You will have to overclock this thing to make it work in games you mentioned. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 18, 2017 Author could u send me the link to a good motherboard and ram Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
