as above something with a 1060 would be a good way to go, nothing less than a 4core. personally id get a desktop for CAD over a portable device, but if you are going for portability...lenovo is good, nice designs, but maybe something like a ASUS if you can (doesn't have to be gamery, just something with good power.)
https://linustechtips.com/topic/807556-need-help/#findComment-10147780
On 7/14/2017 at 6:14 PM, Damascus said:
I would actually get a decent gtx 1060 laptop with a quad core i7.  You need that extra power.
For CAD? Lol no you can edit CAD documents just fine with dual core i5s
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/807556-need-help/#findComment-10147870
depends what...it's the same thing saying you can edit videos on a duo core i5. just that there 720p and minimal editing involved.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/807556-need-help/#findComment-10147926
I guess you have experience with that but I found working on a 6700hq a crappy experience, maybe desktop CPUS have spoiled me.
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/807556-need-help/#findComment-10147929
How you get around that is setting your preview to 1/4th or lower and you just edit. Premiere will run on just about anything.
That being said my dual core MBP has no problem editing 1080p the full preview resolution with color correction and variations of cuts, and layers.
https://linustechtips.com/topic/807556-need-help/#findComment-10147933
sure.
Laptop Main
https://linustechtips.com/topic/807556-need-help/#findComment-10147968
Just now, Pendragon said:
sure.
I mean I have one, and I am certified in Adobe Premiere CC so.....
https://linustechtips.com/topic/807556-need-help/#findComment-10147972
sure
Laptop Main
https://linustechtips.com/topic/807556-need-help/#findComment-10147973
sure
Do you want my certificate?
https://linustechtips.com/topic/807556-need-help/#findComment-10147975
i wasnt doubting ur certificate.
Laptop Main
https://linustechtips.com/topic/807556-need-help/#findComment-10147991
Well there is no other reason to say sure in that context so......
https://linustechtips.com/topic/807556-need-help/#findComment-10147996
the argument is the same as me saying, duo cores can run my excel models just fine, but i hate performance and want less for my money so I'm not getting a quad core or a GPU. Cause fuck it.
A Dell 7567 will outedit the shit out of any duo core 100% all the time because Primere has 0 software optimization and is entirely reliant on hardware. Same thing applies to CAD. Exactly ZERO profession CAD software is optimized for Mac OS so it's entirely hardware reliant again. There is 0 reason to get a sub performing laptop when he can get a great performing one that will meet his present and future needs.
Laptop Main
https://linustechtips.com/topic/807556-need-help/#findComment-10148021
Exactly where did I say he should get a MacBook? Even If I did the only MacBook he could afford would be the MacBook Air.
https://linustechtips.com/topic/807556-need-help/#findComment-10148023
And can you point me to where I challenged that? If I wanted performance I could just use FinalCut and obliterate that Dell.
https://linustechtips.com/topic/807556-need-help/#findComment-10148024
did i mention a macbook??? anywhere??? it's just a general hardware comment.
it was an analogy, if you read the following sentence.
this is the statement i'm challenging. just cause you can edit things on duo cores doesn't mean it's optimal or even enjoyable. there are reasons why people more powerful laptops for CAD. Not everyone likes to deliberately gimp themselves.
Laptop Main
https://linustechtips.com/topic/807556-need-help/#findComment-10148036
MacOS implies either a MacBook, iMac, Mac Pro, or Mac mini no other way of interpreting that within the EULA of MacOS.
https://linustechtips.com/topic/807556-need-help/#findComment-10148043
MacOS implies either a MacBook, iMac, Mac Pro, or Macmini no other way of interpreting that within the EULA of MacOS.
I don't get how you still don't get what I'm saying. Firstly there are 3 major platforms in the world. Linux is primarly for coders and programmers. Mac and WIndows are left. If a program is not optimized for MacOS, it means that it's entirely hardware reliant. Hence you need more hardware to run the program. CAD has 0 programs optimized for MacOS. Hence he needs better hardware to run CAD applications.
Hence your argument that it runs fine on a duo core is both ignorant and unnecessary. he should get as much hardware as he can to run \as most optimally he can.
On 7/14/2017 at 8:44 PM, jpfeif said:
I need a good laptop that is under 1200 U.S.D
https://www.gentechpc.com/product-p/sager-np7850.htm
^ this is what you should get for max performance
get the Dell 7567 for maximum quality of life + slightly less performance.
Laptop Main
https://linustechtips.com/topic/807556-need-help/#findComment-10148060
But its true, its not the best performance but its true.
https://linustechtips.com/topic/807556-need-help/#findComment-10148064
perhaps i should just comment to anyone looking to play games - hey, my duo core runs games fine at 720p at low settings. runs fine. it's 100% true too.
Laptop Main
https://linustechtips.com/topic/807556-need-help/#findComment-10148068
I dont think you know how powerful dual core CPUs can be. Most games only use 2 cores anyway.
https://linustechtips.com/topic/807556-need-help/#findComment-10148071
this even more factually untrue than your previous comment. jesus.
rip facts #macuser
Laptop Main
https://linustechtips.com/topic/807556-need-help/#findComment-10148078
