Greetings.
I have an issue I have been trying to figure out, I am currently running a 1080Ti and a 980Ti as a Physx card with a 850W PSU, I am concerned if the PSU can handle another 1080Ti in SLI at full load.
Thanks anyway
-MSI Z390 ACE        -Samsung M.2 SSD 960 EVO 250 Gb
-I9 9900K 5.0 Ghz                                                            -Samsung SSD 850 EVO 500 GB
-2 x MSI 1080Ti Gaming x 11Gb SLI                              -4Tb + 2Tb Seagate HDD
-Gskill DDR4 Trident Z RGB 32 GB 3000 Mhz              -Corsair RM850X
-Corsair Obsidian 750D Airflow Edition                       -Corsair Hydro 110i GTX
https://linustechtips.com/topic/806934-psu-power-draw-concern/
1 minute ago, Leviathen said:
Greetings.
Thanks anyway
so you're asking if 850 is enough for 2 1080Ti's and a 980Ti?
i don't think it will.
but why the physx card tough? cards these days can handle physx just fine. sometimes even better then a dedicated physx card!
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136708
Yeah no the 980Ti will be sold to a friend if I upgrade to the SLI setup
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136712
ooh that makes sense.
850 should handle 2 1080Ti's just fine. i think even a 650/700 PSU could handle it, but i might be stretching it a bit :P
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136720
are you sure because when I put my system in a Power draw calculator it comes out to over 900 Watts
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136723
those calculators are pretty inaccurate. my system with a Titan X and a 4960X only draws like 450Watts under load. you really should be fine!
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136728
Ok hopefully it will be enough ordering right now, btw how do you get your set up to show up at the bottom of the post ?
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136746
it's called a signature. you can edit it in your account settings :)
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136774
Ah so, found it, thank you ! :)
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136856
That is a stretch. 1080 Tis go well into the 300W range ...
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136899
so you are saying it's not enough ?
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136938
I am saying 650 would be 'hela' retarded and 700 would be a far stretch for a 1080 Ti SLI system. This is not meant to sound insulting.
EDIT: About the 850W PSU. That is about the minimum I would go for with SLI and probably not what I would personally be comfortable with running 1080 Tis on.
3.Use
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136953
Wait no no no, I did not want to make it look like i was insulted ? How did you come to that conclusion no what I was asking is if the 850W will be enough ?
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136955
I didn't realise youa re the OP and was refering to the person quoted when adding the insulting prevention disclaimer :P
3.Use
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136970
1 hour ago, Leviathen said:
Greetings.
Thanks anyway
Just get rid of the 980 Ti.... I don't think it even makes sense as a Physx card as it uses so much power and PhysX is kinda worthless TBH
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10136977
Ok so guys you where right it is working perfectly and this system is a beast ! Thanks for the help
https://linustechtips.com/topic/806934-psu-power-draw-concern/#findComment-10164895
